RV.Net Open Roads Forum: No rear overload spring on my new 2012 Ford F250?
 > No rear overload spring on my new 2012 Ford F250?
Americamper
Anniston AL
Posted: 04/04/21 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Just noticed my new 2021 F250 did not come with a top overload spring like my old 2000 F250 has. Anyone have experince hauling a loaded 2500# TC on one? I have not been able to find a new F350 in my area to look at the rear springs on them. Also the spring pak has less leafs but looks beefier than my old truck. I have not loaded the TC yet, waiting on the frame mounts for tie downs. Just trying to get an idea as to what I might have to do , if anything. Old truck came with camper package but I never knew exactly what that consisted of.
2000 F250 Superduty 7.3 SB SRW, E rated Michelins, Torklifts, fastguns,2004 Northstar Laredo, , Ducati Hypermotard 1100, KTM 250XC
Monterey, California
Posted: 04/04/21 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I understand as follows...
With the most recent version of the Ford F-250, the 2021 Ford F250, these are the add-ons offered in the Super Duty camper package:
Rear stabilizer bar—often referred to as an “anti-roll/sway bar,” this feature makes the vehicle feel more secure and stable as you drive and prevents the tires from coming off of the ground. For instance, a heavy load in combination with the speed of your vehicle going around a sharp corner could cause the rear body of the vehicle and the tires to lose contact with the ground below if the sway bar isn’t present.
Rear auxiliary springs—rear auxiliary springs give the truck more support and allow it to carry more weight without the risk of blowing out or over exhausting the primary springs. These are more or less the backup springs, given they are also often referred to as helper springs, and allow the truck to ride more smoothly.
Slide-in camper certification—this is recommended for all Ford trucks that plan on being used to haul a slide-in camper. A slide-in camper certification comes with the purchasing of a camper package with the Ford F250 and certifies that the truck is safe to use when carrying a slide-in camper.
Signature increased capacity front springs—this is something you will definitely want to have on any truck you plan on using to haul something of significant weight. Also known as heavy-duty coil springs or overload springs, increased capacity front springs take on the weight of whatever is being hauled and absorb it. Having your truck equipped with increased capacity front springs increases the load capacity.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Buzzcut1
Norcal
Posted: 04/04/21 11:28am Link  |  Quote  |  Print  |  Notify Moderator
look at the bottom of the leaf pack. if there is a spacer between the short bottom leaf and the one above it you can easily install a lower stableload without needing to drill. The lowers make a huge difference in how the rig carries a load in the bed
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Old-Biscuit
Verde Valley
Posted: 04/04/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thought the difference between 250 & 350 was the addition of Overload Spring on 350
You can have a spring shop add one
You can add Stable Loads
According to FORD....Camper Package
*Rear Stabilizer Bar
*Auxiliary Rear Springs
*Increased Front Spring Capacity
You have options..........
US NAVY------USS Decatur DDG31
Kayteg1
California > Nevada
Posted: 04/04/21 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Evidently Ford engineers concluded the truck doesn't need them.
Bear in mind since 2017 Superduties are 500 lb lighter than older models, so with the same payload, the rear axle is having close to 500lb less load.
My 2017 F350 dually was hauling camper (scaled at 6300 lb at 1 time) without any modifications.
Americamper
Anniston AL
Posted: 04/04/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Spacer or lift block is between the axle and first short spring.
billtex
RI
Posted: 04/04/21 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
That’s why you order the camper pkg...or just get the F350.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
Americamper
Anniston AL
Posted: 04/04/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
It was really hard to just find a truck that I liked in my neck of the woods . So when I found a truck I liked with the 7.3 gas engine I jumped at it.
Posted: 04/04/21 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
And 4 years later you still believe this. And even if the “350lbs saved in Al body and new frame , with some of the savings reinvested in heavier components “
did result in a little theoretical weight savings, it wouldn’t significantly affect payload capacity over the rear axle.
2017 Heartland Torque T29
Kayteg1
California > Nevada
Posted: 04/04/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
That's what special orders are for.
I could not be happier with building my own truck. I got options like 360 cameras and ultimate tow package I wanted and saved ton of money on avoiding options I had no use for.
Impulse jumping seldom ends with full satisfaction.
