CA Traveler
The Western States
The advantage of RO is cleaner better tasting water. The disadvantage is 3-4 gallons of waste water for every gallon of clean water. When boondocking the pump also has to run more.
Returning the unfiltered RO waste drinking water to the tank adds to the tanks contaminates which increases as the tank empties. So increased filter replacement. Most of the tank water however is used for other purposes like washing hands etc and doesn't go through the drinking water RO system.
So pros and cons to cleaner water. But maybe there are no cons - I have a RO system at home because I don't like the water taste... But there is the initial cost and filter replacement and my tank (bladder) failed once and the second tank is starting to fail.
Just my 2 cents...
2014 Grand Cherokee Overland
Bob
TechWriter
Part-Timing Again
philh wrote: TechWriter wrote: Plus, you can plumb an RO system so that the waste water goes back into your water tank so there's no waste.
no issues with the "dirty" water going back into the tank?
Not really. RO systems have multiple stages: typically 2 or 3 filters (sediment, carbon block, etc), then the RO membrane itself, and finally post filters like "water polishing" or adding minerals.
The waste water or brine comes from the RO membrane so the water has already passed through filtration that most RVers use anyway.
If anything, the RO brine is hard water, not "dirty". TDS (Total Dissolved Solids) levels in ppm are usually used to measure RO system water quality. For example, one of my measurements was . . .
- "Fresh" (incoming) water: 242 ppm
- RO treated water: 34 ppm
- RO Brine: 202 ppm
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 gasser)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 gasser)
www.rvSeniorMoments.com
DISH TV for RVs
TechWriter
Part-Timing Again
Depends where you put your RO pre-filters. Mine filtered water before, not after, the water hits the holding tank. So no strain on the filters.
DancinCampers
Louisiana
I run off my tanks exclusivly. A 10 Micron sediment filter, then a 5 micron sediment filter, then a 5 micron carbon filter, then a 100 gallon/day RO membrane.
In New Orleans I have 300 + PPM TDS in, 12 PPM out.
Dan & Sharon (Kasey, Our Yorkie, RIP 9Jan'05-26Jul'17)
2012 Winnebago Journey 36M
2006 Jeep Liberty, Blue Ox Aventa II, SMI Silent Partner
If You Obey All The Rules, You Miss All The Fun
