RV.Net Open Roads Forum: Travel Trailers: Poop in outside sink
 > Poop in outside sink
Huntindog
Phoenix AZ
Posted: 04/05/21 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
cougar28 wrote:
I don't ever recall any sink being plumbed into a black water tank on a rv. Either something else is happening or it plumbed wrong.
It is actually pretty common. All 4 of my Trailers have been that way.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
1380 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
kmdiddy
Shermans Dale, PA
Posted: 04/06/21 06:23am Link  |  Quote  |  Print  |  Notify Moderator
I am positive it is black water, trust me...the things I have seen cannot be unseen. So I tore apart the sink last evening and it appears that a mouse decided to chew the catch in the sink tail piece to get into the pipe. Then it decided to chew the internals of the waterless drain which cause my issues.
I really like the suggestion to put in a ball valve. That is a great idea. The only issue is that I do not have enough room to have the waterless trap and ball valve installed. It would be one or the other for me.
kmdiddy
Shermans Dale, PA
Posted: 04/06/21 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Also...I was totally unaware of plumbing a sink to black water tank as well however after much research, its quite common and beneficial. I will be using the trick of filling the tank with the outside sink going forward before dumping.
bgum
South Louisiana
Posted: 04/06/21 06:34am Link  |  Quote  |  Print  |  Notify Moderator
On Airstream Bambi there is only one tank. The manual states to insert a drain stopper in the shower when towing as is possible for tank contents to spill from the drain in a hard stop.
Get a stopper.
kmdiddy
Shermans Dale, PA
Posted: 04/06/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
@bgum thanks! I also thought of that as well. I think I am going to do that as well. I have used the rubber seals with washers and a wing nut in the past to seal off lines. I am going to look for one of those to do the same here.
I ordered a steel tail piece replacement. I will take that to the hardware store to size the appropriate seal. Thanks for the advice.
falconbrother
North Carolina
Posted: 04/07/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Sinks drain into the grey tank. How is it possible for black tank contents to enter any sink or bathtub? The black tank sits under the pooper.. Nothing else runs into it.
camperfamily
New Jersey
Posted: 04/07/21 08:56am Link  |  Quote  |  Print  |  Notify Moderator
falcon brother, some sinks do indeed drain into the black tank. Seems to go against logic of grey/black separated tanks but its done.
2011 Cougar 322QBS
2007 Pilgrim 278BHSS (Sold)
2013 F350 CC LB 6.7
2002 F350 CC LB PS (Retired)
B&W Companion Hitch
cougar28
Lowell,AR USA
Posted: 04/07/21 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Seems to me some black tank drain into sinks also! LOL
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
time2roll
Posted: 04/07/21 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
blaczero wrote:
time2roll wrote:
I would be looking at putting a regular ball valve on that drain. Open when parked and in use. Otherwise close it.
a ball valve on PVC drain? Never seen that.
1.25" or 1.5" is available at any decent hardware store.
I would not trust a stopper.
RV gate valve would be fine too.
675w Solar pictures back up
Bobbo
Wherever I park
Posted: 04/07/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
If you will read the entire thread, you will see that some sinks, indeed, do drain into the black tank. My first RV had one plumbed that way.
Bobbo and Lin
