RV.Net Open Roads Forum: General RVing Issues: Bear Spray
 > Bear Spray
Page of 5
#1Flyboy
California
Posted: 04/05/21 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon
JimK-NY
NY
Posted: 04/05/21 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
In my experience, which is a lot of time in bear country, bear bells are close to useless. Most of them are not very loud. Second bears in Yellowstone, Glacier and other heavily visited areas become habituated to humans. They are not hunted and often just don't leave even if they hear you. Bears do not have especially good hearing.
JimR 1
Custer South Dakota
Posted: 04/05/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
pulpwood007 wrote:
Why buy local at Yellowstone? What's different about local vs. what's available on Amazon?
I would buy in the local area? Because I would be more assured that a local purchase would be in compliance with the area as far as EPA and local laws. Also I would assume that the spray would be fresh, not expired. Bottom line I would trust a local purchase more than an online purchase and I am willing to pay more.
When I camped between Cody and the East Gate the forest service came around and warned us about the Grizzly Bear problem that was there at that time. I purchased my Bear Spray in Cody and not sure but I think I got it at Walmart.
Also if you go into Canada some of the Bear Sprays are not allowed. Just an FYI
JimR
Tal/IL
Central Illinois
Posted: 04/05/21 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
This looks like pretty good source of info on bear spray:
Bear Safety tips / Be Bear Aware
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
kwplot34
home
Posted: 04/05/21 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
While out and about keep an eye out for Bear poop, it's easy to identify. It has little bells in it and smells like bear spray.
Boon Docker
Posted: 04/05/21 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
QCMan
Independent Republic of Horry
Posted: 04/06/21 08:10am Link  |  Quote  |  Print  |  Notify Moderator
On a side note, large containers of bear spray are allowed into Canada and any that could be concealed are not. Apparently they are saying that a lot of pepper spray is ok but a little isn't.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Kavoom
Kansas
Posted: 04/06/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
bobsallyh wrote:
Pick up a can somewhere in West Yellowstone, YNP it's self, or a sporting goods store when get near YNP. They are priced fixed from what I have seen and when I bought a can. Forget branding. You can also rent in YNP.
Hit a Costco in Western MT. Two for one price... One to practice, one to use. They will charge you 40 bucks in the park or surrounding area...for one. They all are about the same.
Hit Amazon for a small handheld boat horn https://www.amazon.com/Seachoice-46211-1-5OZ-Signal-Horn/dp/B001B3DEN0/ref=asc_df_B001B3DEN0/?tag=bingshoppinga-20&linkCode=df0&hvadid=&hvpos=&hvnetw=o&hvrand=&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=&hvtargid=pla-4584070147615899&psc=1
You want a defense in depth with them. The best defense is to travel with someone slower than you you don't particularly care for...but...If you see one that displays any interest in you whatsoever, blow the boathorn at them, quick short. Use your unfavored hand e.g. left if you are a righty...
If they move closer, longer and short bursts. This will make them at least stop for a moment and make their ears go back... That buys you time if it doesn't make them turn around and go. The time should be used so you can unlimber your bear spray with your favored hand instead of trying to get to it in a panic... Learn how to flip off the plastic trigger protector with one hand. Keep it pointed away from you.
IF, they keep coming, make sure you are upwind from them...move slowly and away so the wind is at your back relative to the bear. Do NOT run. That triggers them... They move like lightning when they want to and can outrun the fastest man by double his speed. Most of the time unless you trigger their chase reflex or come up unexpectedly close...they will come carefully and not superfast toward you but most the time they don't want to have anything to do with you.
Keep using the boat horn until they have made it perfectly clear that isn't going to stop them. If they stop and huff and sort of jump up and down on their front legs, it is a warning. If they just keep coming, you got a problem. Drop the boat horn. Aim the bear spray. (Be sure to try the bear spray out before you go into bear country so you know how far it shoots and how it spreads out. That will help you judge the most opportune time to use. It generally stops them in their tracks at least at first. It takes guts to stand while they move quickly toward you, but that is your only hope.
Now, at this point, I usually also ensure that I can get my hands on my handgun (Ruger Alaskan). I will make a decision later on whether to use it on me or the bear... I have seen too many emergency room pics that are frankly horrifying... We used to have to give rabies prophylaxis recommendations for victims.
Now that you are really concerned, remember, 90% of the time, they know you are there and will hear you first and you will never see them. Most of the rest of the times, you will see them far away across the side of a mountain. Do NOT attract their attention if you have a choice. Curiosity can lead to a predatory assessment on their part... You do not want to be a part of that equation at all if you can help it. So, get behind a rock, bush, trees and take your pictures without noise. At all times keep at least a couple of football fields between you and them and NEVER take your eyes off them.
I have been the subject of their interest on two occasions. The boat horn worked both times. One much less than one football field... They supposedly are NOT in my mountains (Elkhorns) but that pic one of my neighbors showed me of a place less then three miles from my house last summer sure wasn't a black bear. We had fish wildlife and parks put one of the wheeled barrel traps in my neighbors yard/acreage here a few years ago.
Montana is the last best place. I kind of like not being the top predator. It keeps you on your toes in a subtle way you don't get anywhere else in the continental US. And, do not underestimate mountain lions either... How about a 150 lb kitty cat with claws the size of your small finger. My friend (late 60's) hurt his knee on a hike within a mile of our neighborhood. He was limping. He sat down on a rock and looked up at one in a tree getting in that ready to pounce mode... He yelled and screamed and waved his walking stick and it ran... It was likely tracking him for quite awhile. It recognized his limp as a weakness. Dogs and small children are viewed as snacks. AND, otters are not cute little animals. They enjoy killing dogs who swim in to play with them and then go after the humans coming in to try and save the dogs... Yep, rabies prophylaxis every time...and dead dogs...
AND PLEASE, don't try to pet anything. Watching bison throw people 20 feet in the year may be a Montana form of entertainment, but I'm pretty sure it isn't pleasant for the human involved. But hey, NO rabies prophylaxis for that one unless he bites you... Mostly they just gore you...
wapiticountry
Mountain West
Posted: 04/06/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Yellowstone averages about 1 bear attack per year. It also averages close to 4 million visitors each year. I suggest you buy a lottery ticket at the same time you buy the bear spray. That would insure that you are covered should your luck swing to the very end of either side of the luck bell curve.
pulpwood007
Hemphill, TX
Posted: 04/06/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
That's the kicker. We are not doing any backwoods hiking, and will probably be around the masses most all the time. Maybe a few well traveled trails.
When I was younger I'd be in all for some backpacking, but now it's more of a sightseeing trip. Probably the only time I might need spray is if I step outside the trailer at night.
I have watched the videos of folks doing very stupid things around bison. Can't figure out why they are so fascinating. I've seen them all over the country and they are dirty, stupid, mean animals. Certainly not something anyone should want to get close to.
Page of 5
 > Bear Spray
