RV.Net Open Roads Forum: Truck Campers: Camper type wood burning stove for home...
 > Camper type wood burning stove for home...
d3500ram
Colorado
Posted: 04/06/21 09:04am Link  |  Quote  |  Print  |  Notify Moderator
To clarify, I am not intending to put one in my camper (I do not have one anymore...)
...but, I recall an article or topic post some years ago about an upscale camper (I think it was a TC) that had a very modern, sleek and efficient wood burner it it. I am trying to find that post or article to investigate to perhaps install one of those for my house renovation.
As I recall, the stove was cylindrically tall and somewhat small for the heat it was able to generate.
I think it was manufactured by a company from Northern Europe(?) and was not cheap.
Does anyone recall that stove that I am trying to describe?
ON EDIT:
changed subject line
07 apr 21/ 1548 mst
* This post was edited 04/07/21 03:50pm by d3500ram *
gbopp
The Keystone State
Posted: 04/06/21 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I don't remember the article but, I do remember looking for small wood stoves.
This may be what you are talking about or it's something similar.
KIMBERLY WOOD STOVE
d3500ram
Colorado
Posted: 04/06/21 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I believe that is the one I remember. Thanks!
Folks, if there are others out there similar to this that might be available please bring 'em up.
valhalla360
No paticular place.
Posted: 04/06/21 10:03am Link  |  Quote  |  Print  |  Notify Moderator
You find them occasionally on boats. Basically the size of a bread box (does anyone have those anymore or is the reference too dated?).
Make sure the chimney is properly installed, so it doesn't set the place on fire but otherwise fairly simple.
If you just want to play with fire, they will work but given we get a good month out of a 20# propane tank in moderately cold weather (and we have 2 tanks), not a practical solution.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
IAMICHABOD
Sunny So Cal
Posted: 04/06/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
There was a member that had one in his Class C. Also from Colorado. He hasn't been back for a long time but I found it in my archives.
See It Here
Former El Monte RV Rental
Buying A Rental Class C
Quartzsite, AZ
Posted: 04/06/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Wood for a campfire is fun. Wood for space heating takes lots of time and effort.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Kayteg1
California > Nevada
Posted: 04/06/21 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Working in house remodeling I have seen lot of things that "work" but I would never consider them safe.
Seeing all the crack on wood "sealing rings" in linked post, brings some of those memories.
Sheetmetal behind the stove will not help much when you have it lined against plastics and vinyl.
You need 5/8" drywall or even better Wonderboard for fire safety.
Posted: 04/06/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
This public service message brought to you by Fire Marshall Jim!
2017 Heartland Torque T29
Jack_Diane_Freedom
Burlington Ontario Canada
Posted: 04/06/21 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Try looking at winter camping websites as there are a good number of small woodstoves that people use quite safely in tents. Various sizes are available and can be used for cooking.
mellow
Salisbury, MD
Posted: 04/06/21 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
You can see a TC install of a wood stove here: https://www.tinywoodstove.com/the-one-of-a-kind-adventure-rig-basillynch/
I personally wouldn't do it since it uses kindling sized wood and takes up way to much room.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
