RV.Net Open Roads Forum: Technology Corner: Difficulty Finding Adaptor
 > Difficulty Finding Adaptor
mr. ed
Amarillo, Texas
Posted: 04/06/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I'm trying to attach a wired mouse to my iPad. I don't like Bluetooth mice because I've used them in the past and always had problems. My wired mouse has a USB-A plug and the iPad has a lightning port. I need a lightning (male) to USB=A (female) adaptor in order to accomplish this. All I can find are adaptors with USB (male). Walmart has dozens of adaptors, but they're all USB (male). I even checked online without success. Maybe they aren't manufactured for some reason. I would especially prefer lightning (male) to USB-A (female) with no wiring in-between, just a simple plug-in adaptor. In the meantime, I can continue using the track pad on the external Bluetooth keyboard, but a mouse would be preferable.
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
2oldman
NM
Posted: 04/06/21 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
This doesn't work? I do see it says 'camera.' Also, there's no such thing as a wired mouse with a lightning plug?
* This post was edited 04/06/21 12:56pm by 2oldman *
agesilaus
North Florida
Posted: 04/06/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Try this Amazon
Amazon, tho vile, has jast about everything. I went to electronics and typed in USB female to Lightning male
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
mr. ed
Amarillo, Texas
Posted: 04/06/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the research, 2oldman. What concerns me, as you pointed out, is that it's meant to attach a camera to an iPad. So, I can't be sure it will work with a mouse (maybe different internal wiring?)
mr. ed
Amarillo, Texas
Posted: 04/06/21 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
Try this Amazon
Thank you, Agesilaus. Looks promising. I especially like that two of the adaptors have no wiring, just plug directly to devices. I don't know any reason why it couldn't work with a mouse, but maybe worth a gamble. [emoticon]
wanderingaimlessly
Buggs Island lake
Posted: 04/06/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
If I understand what you need, this could help.
double female usb connector
mr. ed
Amarillo, Texas
Posted: 04/06/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
That,s not quite it, but thanks for searching. I need lightning connector male to USB-A female. The ones on Amazon, noted above, seem correct. They’re meant for use with an iPhone, but may work with a wired mouse; not sure. Thanks
Seattle Steve
Tucson
Posted: 04/06/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, Ed, but you should stop looking. Even if you could find or create your own adapter, it would not work. IOS is not designed to use a wired mouse and the IOS software does not support it. Frankly, iPads are not designed for mice; they are touchscreen devices.
mr. ed
Amarillo, Texas
Posted: 04/06/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Steve, I believe the 7th generation iPads now support mice, but I’ll check further. [emoticon]
Yep, I just confirmed it online. The later generation iPads can now use a mouse!
Fizz
Ottawa, Canada
Posted: 04/06/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it work.
I've tried it but I'm so use to using a touch screen I gave up on it. I found it slow and awkward.
