RV.Net Open Roads Forum: Technology Corner: Difficulty Finding Adaptor
 > Difficulty Finding Adaptor
mr. ed
Amarillo, Texas
Posted: 04/06/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I'm trying to attach a wired mouse to my iPad. I don't like Bluetooth mice because I've used them in the past and always had problems. My wired mouse has a USB-A plug and the iPad has a lightning port. I need a lightning (male) to USB=A (female) adaptor in order to accomplish this. All I can find are adaptors with USB (male). Walmart has dozens of adaptors, but they're all USB (male). I even checked online without success. Maybe they aren't manufactured for some reason. I would especially prefer lightning (male) to USB-A (female) with no wiring in-between, just a simple plug-in adaptor. In the meantime, I can continue using the track pad on the external Bluetooth keyboard, but a mouse would be preferable.
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
2oldman
NM
Posted: 04/06/21 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
This doesn't work? I do see it says 'camera.' Also, there's no such thing as a wired mouse with a lightning plug?
* This post was edited 04/06/21 12:56pm by 2oldman *
agesilaus
North Florida
Posted: 04/06/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Try this Amazon
Amazon, tho vile, has jast about everything. I went to electronics and typed in USB female to Lightning male
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
mr. ed
Amarillo, Texas
Posted: 04/06/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the research, 2oldman. What concerns me, as you pointed out, is that it's meant to attach a camera to an iPad. So, I can't be sure it will work with a mouse (maybe different internal wiring?)
mr. ed
Amarillo, Texas
Posted: 04/06/21 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
Try this Amazon
Thank you, Agesilaus. Looks promising. I especially like that two of the adaptors have no wiring, just plug directly to devices. I don't know any reason why it couldn't work with a mouse, but maybe worth a gamble. [emoticon]
wanderingaimlessly
Buggs Island lake
Posted: 04/06/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
If I understand what you need, this could help.
double female usb connector
mr. ed
Amarillo, Texas
Posted: 04/06/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
That,s not quite it, but thanks for searching. I need lightning connector male to USB-A female. The ones on Amazon, noted above, seem correct. They’re meant for use with an iPhone, but may work with a wired mouse; not sure. Thanks
Seattle Steve
Tucson
Posted: 04/06/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, Ed, but you should stop looking. Even if you could find or create your own adapter, it would not work. IOS is not designed to use a wired mouse and the IOS software does not support it. Frankly, iPads are not designed for mice; they are touchscreen devices.
mr. ed
Amarillo, Texas
Posted: 04/06/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Steve, I believe the 7th generation iPads now support mice, but I’ll check further. [emoticon]
Yep, I just confirmed it online. The later generation iPads can now use a mouse!
Fizz
Ottawa, Canada
Posted: 04/06/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it work.
I've tried it but I'm so use to using a touch screen I gave up on it. I found it slow and awkward.
