RV.Net Open Roads Forum: Technology Corner: Difficulty Finding Adaptor
 > Difficulty Finding Adaptor
mr. ed
Amarillo, Texas
Posted: 04/06/21 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I’ve pretty much decided to go with a Bluetooth mouse after all. I found a good one on Amazon for less than $16. It’s a. Microsoft mouse (yes, that’s right). User reviews are mostly excellent. Thanks to all who added their suggestions on this thread.
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
Posted: 04/07/21 04:52am Link  |  Quote  |  Print  |  Notify Moderator
If it is a computer accessory and IF it actually Exists.
I'd check with my favorite PI shop. MICRO-CENTER (you can find them on line)
(That's PI as in Raspberry PI not PIE as in what you make with apples)
Fizz
Ottawa, Canada
Posted: 04/07/21 05:55am Link  |  Quote  |  Print  |  Notify Moderator
Do you have more than one PC or device that uses bluetooth?
If at some time you can't connect to the mouse chances are it connected to another device. This one really had me baffled at first.
Scottiemom
Posted: 04/07/21 06:08am Link  |  Quote  |  Print  |  Notify Moderator
I bought a set of three adapters on Amazon. Two short ones and a longer one. The short one I used for a mouse. I am like you, I just like a wired mouse, although I do use the touch pad as well.
Mine is USB to the Thunderbolt connection, which I think may be the "lightening" port you mention. I can also connect my printer using one as well.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
MrWizard
Traveling
Posted: 04/07/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
This will do it
One is lighting male to C female
Two is C male to usb A female
So you get usb A female to lighting male, which lets you plug in a usb A male to a lighting female port
They came in a set I bought on Amazon in April of 2020
Cost was low 7 or 8 dollars, set came with 6 different
adapters, all possible data pins are used, these are for data transfer interfacing, device communication, Not charge cord adapters, a camera to lighting adapter is data communication and should also work
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
mr. ed
Amarillo, Texas
Posted: 04/07/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
That looks pretty good, Mr Wizard, but, as I stated above , I’ve already ordered a Bluetooth mouse from Amazon. I If it’s not satisfactory, I’ll go ahead and adapt my wired mouse to my iPad. Thank you. Ed
Thank you also, Scottiemom and Wa8yxm., and others.
1492
Arlington, VA
Posted: 04/07/21 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Liked the idea of this adapter that I ordered a similar one on Amazon.com for 9.99. Will test with USB Keyboard/Mouse on my iPhone and iPad once I get it.
Apple's own documentation states it supports USB mouse in iOS v13 and higher.
mr. ed
Amarillo, Texas
Posted: 04/08/21 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Look forward to results of your test, Mod.
philh
Belleville MI
Posted: 04/08/21 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Got the part today, recovering from surgery right now.
mr. ed
Amarillo, Texas
Posted: 04/09/21 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Best wishes, and get well soon. [emoticon]
