RV.Net Open Roads Forum: Tech Issues: Follow up Solar Question
 > Follow up Solar Question
Katdaddy
Petal, MS USA
Posted: 04/14/21 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
Besides the controller's spec for connection sequence for whatever reason to do with that controller, any "12/24" controller wants you to connect to the battery first so it can "see" whether your system is 12v or 24v before it is connected to the array
Yep! I learned this the hard way. I did it backwards and the controller was reading for 24v. I thought I had torn it up right off the bat.
Little by little, one travels far - J.R.R. Tolkien
There ain't no surer way to find out whether you like people or hate them than to travel with them. - Mark Twain
PerryB67
Lanesboro, Minnesota
Posted: 04/21/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
A year ago we purchased a Renogy 100 watt suitcase. From talking to other suitcase users the wires will be too short to reach sunlight. We have three 15' 10 gauge Zamp cables with SAE plugs. Renogy provided us the proper SAE adapters for our portable.
I thought I'd never use 45' of cable until two months ago in Chiricahua National Monument. We were there for 7 days in cold weather. The furnace blower is our biggest user, and despite 220 amps (110 useable) we would have killed the batteries without 45' of cable.
When running 45' of 10g cable you want the controller inside the camper, as close to the batteries as possible. 18 volts can get by on a smaller wire than 12 volts.
We installed a Victron 110/20 controller with an SAE port on the outside of the camper leading to the controller. Between the batteries and controller I installed a 20 amp fuse that can also double as a disconnect.
Enjoy,
Perry
2018 Escape 5.0
2019 F150 Max Tow, Max Springs, 3.5 EB Quad Cab
Victron 712, Victron 100/20, Victron 100/30
GoPower 170 watt, and three Renogy 100 Compact watt panels, all in parallel
260 ah Soneil SiO2 batteries
