RV.Net Open Roads Forum: Truck Campers: Front bed dipping with camper help
 > Front bed dipping with camper help
JakeTravels
Canada
Posted: 04/07/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
Help/Advice: I have a 2008 Ford F-250 super duty longbox with an extra leaf spring installed. I bought a 2000 Sun Lite 6 ft camper with overhang. The weight of the camper is far below the capacity for this set up but I’ve noticed the front end of my truck box has dipped noticeably. Most of the weight is in the back of the bed and did not even dip the slightest when loading. I’m wondering the reason for the front dip.... my two guesses are the uneven center of gravity or my front turnbuckles are too tight. How do I fix this??? Is this unsafe to drive?? I’ve been driving on service roads and highways with no issue yet. Any input is greatly appreciated, thanks.
Posted: 04/07/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Frame bent, body/bed mounts rusted out/crushed are a couple things come to mind.
Sounds like truck issue not camper.
2017 Heartland Torque T29
joerg68
St. Ingbert, Germany
Posted: 04/07/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
You mean the front of the bed sits lower than it is supposed to and the body lines no longer line up with the cab?
Just for clarification You have a short bed (6') camper on a long bed - is there unused space in front of the camper?
Have you looked underneath the bed? It is not unusual for the bed supports on these trucks to rust out. They may have crumbled under the weight of the loaded camper combined with rough roads.
If you want to post pictures, you can use http://photoposting.is-great.net/
midnightsadie
ohio
Posted: 04/07/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
or the over hang on the camper is rotted and your pulling it down? hope not ,
JakeTravels
Canada
Posted: 04/07/21 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I’m thinking it might be the bed supports are rusted out. Going to the mechanic in two days. It’s an hour away, will this be okay to drive?
JakeTravels
Canada
Posted: 04/07/21 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
It is a short bed camper on an 8 ft bed. I use the unused space for my gear for work which weighs over 100 pounds.
Mfan
Otsego,Mi
Posted: 04/07/21 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't drive it that far.
Tyler0215
Iowa
Posted: 04/07/21 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Take the TC off before driving that far. It can't be repaired with the camper on anyway.
midnightsadie
ohio
Posted: 04/07/21 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
maybe raise the camper with some 4x4 for more clearance.
JakeTravels
Canada
Posted: 04/07/21 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
I think I found the issue, rusted out mounts on the right side
I have no option unfortunately to leave the camper anywhere so hopefully I make it to the shop.
I’m in the middle of nowhere with the closest shop an hour away. Let’s hope I make it
