RV.Net Open Roads Forum: Truck Campers: Front bed dipping with camper help
 > Front bed dipping with camper help
ScottG
Bothell Wa.
Posted: 04/07/21 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like they're replaceable and not too bad a job at that: 2008 F250 Bed braces
Best of luck to you.
Scott
ticki2
NH
Posted: 04/07/21 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
If you are in the middle of nowhere you should be able to find a small fallen tree , maybe 6” diameter . Take the weight of the camper off the bed with the jacks . Measure the height and cut a section of log and jam it in between the frame and bed . Lower the camper and between the weight and the tie downs it should stay there if you take it easy .
'68 Avion C-11
'02 GMC DRW D/A flatbed
ticki2
NH
Posted: 04/07/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
BTW , that doesn’t look like an original bed support . So much rust and the bottom of the bed looks new . Somethings amiss
Bert the Welder
Van. Island
Posted: 04/07/21 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you're driving on a road of precision ground, seamless marble, I'd be very weary of driving that anywhere. You do have a responsibility to fellow drivers.
Why not off load where you are staying? Or are you urban camping?
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
Posted: 04/07/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I think you found the problem too...
Second the comment, jack the camper up, jam a couple boards or something in there and let er rip.
* This post was edited 04/08/21 10:58pm by Grit dog *
2017 Heartland Torque T29
schlep1967
Harrisburg, PA
Posted: 04/08/21 06:26am Link  |  Quote  |  Print  |  Notify Moderator
This. Any solid object the right size would work. A piece of fire wood split to the correct size etc.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
valhalla360
No paticular place.
Posted: 04/08/21 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Is there anyplace closer where you can drop the camper?
That is not a good situation for a longer drive.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
mellow
Salisbury, MD
Posted: 04/08/21 07:39am Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue with my 2002 F350, I ended up buying a used truck bed from a 2006 year with same color and the bed came from Texas with 0 rust on it. Yea I paid $1200 (DRW) for it, but I am now set for a long time.
Doing those frame mounts is not an easy job, I started doing it and gave up as you have to have the right tools to do it so it will last.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
fj40cruiser
Minneapolis
Posted: 04/11/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I had that issue when I put a plow on a 06 2500HD. a set of Timbren's did the trick. raised it up 2 inches. you can also adjust the torque keys if they have room for it. I also put 8000lb timbrens on the back of big red and it handles like a dream! Timbrens are the great accept when you take the load off, then it's like driving through a cornfield.
hedgehopper
Denver
Posted: 04/12/21 12:06am Link  |  Quote  |  Print  |  Notify Moderator
From the picture, it looks like the bottom of the cabover is sitting on the roof of the truck cab. If so, the roof of the truck cab could be damaged if you drive anywhere with the camper in the truck bed.
