RV.Net Open Roads Forum: General RVing Issues: Stupid question about tires
 > Stupid question about tires
Page of 5
PartyOf Five
Wheaton, IL
Posted: 04/07/21 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Our mechanic suggested nitrogen in the car tires if we did a rotation as winter approached. Apparentky it doesn't contract and expand as much in the cold and so is better in extreme temps.
That was already a few years ago- the fad seems to have died down.
PartyOf5 appreciating our Creator thru the creation. 5 yrs, 50k
May you find Peace in all you endeavor.
time2roll
Posted: 04/07/21 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Put "nitrogen" in that search box above, I dare you [emoticon]
675w Solar pictures back up
DrewE
Vermont
Posted: 04/07/21 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
The only component of air that expands or contracts significantly differently than nitrogen alone is water vapor. Dry air won't behave much differently at all than pure nitrogen (and air is mostly nitrogen anyhow)--all the component gasses are very well well described by the ideal gas law.
Some gasses do interact with rubber a little differently; in particular, carbon dioxide more easily permeates through the rubber itself than most other gasses, though it's not a huge difference and completely irrelevant if your tire isn't perfectly sealed to the rim, or the valve stem leaks microscopically, etc.
In some extreme applications, like airliners and race cars, nitrogen is used to reduce fire risks. For ordinary vehicles and trailers, it's pretty much valueless (but not harmful or worrisome in any way).
pianotuna
Regina, SK, Canada
Posted: 04/07/21 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Crowe,
First there are no stupid questions.
Some aircraft have nitrogen installed in their tires. Once you have taught your RV to fly--I do recommend nitrogen. Until then, compressed air will be fine.
Regards, Don
ktmrfs
Portland, Oregon
Posted: 04/07/21 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
NOT true. all gases follow boyles law PV=RT. since V (volume) is constant, P is strictly a function of T (temperature) where T is absolute temp, E.G. room temp is 273 or so Kelvin
Nitrogen molecules are slightly larger than Oxygen, so pressure drop from migration through the tire will be very slightly less.
2011 Keystone Outback 295RE
bikendan
Camano Island, Wash.
Posted: 04/07/21 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Crowe wrote:
So y'all can call me uneducated, stupid or whatever you like, but the 5th wheel we are looking at comes with nitrogen in the tires. Are there nitrogen pumps available? Can you mix it with air or just swap it over? Just seem weird to me.
This is the biggest scam in the tire industry.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Posted: 04/08/21 04:18am Link  |  Quote  |  Print  |  Notify Moderator
First the only STUPID question is the one you should have asked, but did not.
Second. Nitrogen There has been much debate on this. Nitrogen has some different properties than basic air. It's a large molecule so the gas does not "Migrate" as fast as normal air (Which is 78% nitrogen by the way) now if there is a greater pressure differential (IE: flying high say 10,000 feet) this becomes more important... It also is not as affected by temperature So it is commonly used in aircraft tires.. Which suffer extreme temps and often can be found thousands of feet in the air.
For RV tires.. It's basically a Gimmick. Feel free to use normal Air.
I do suggest a Tire Pressure Monitoring System...
dodge guy
Bartlett IL
Posted: 04/08/21 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Nitrogen does work. It will keep the pressure stable. But the use in auto/RV applications is not necessary. They have their place, which is in aviation and auto racing.
And yes, you can add regular compressed air to nitrogen filled tires. It’s like adding 87 octane to a tank that has 93.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
CapriRacer
Somewhere in the US
Posted: 04/08/21 05:59am Link  |  Quote  |  Print  |  Notify Moderator
ktmrfs wrote:
...... All gases follow boyles law PV=RT. since V (volume) is constant, P is strictly a function of T (temperature) where T is absolute temp, E.G. room temp is 273 or so Kelvin. .....
X2!!
Nitrogen behaves exactly like air when it comes to pressure buildup in tires!
CapriRacer
Visit my web site: www.BarrysTireTech.com
pitch
NY
Posted: 04/08/21 06:05am Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
I see several haulers swear by using nitrogen in the commercial trucks and trailers. Same size trucks and trailers we rv with.
If I went back to hauling I would use nitrogen all around but for just using a truck for pulling my rv trailer regular compressed air works fine.
Your choice.
You see several haulers that are not real intelligent. Did they purge their tires of existing atmospheric pressure air before the nitrogen? If not they have already eliminated the reason for nitrogen to begin with.
Page of 5
