RV.Net Open Roads Forum: Are one ton trucks classified as commercial in some states?
 > Are one ton trucks classified as commercial in some states?
Kayteg1
California > Nevada
Posted: 04/08/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
jimh425 wrote:
Yes, but you mostly you only have to worry about your state.
In CA all commercial vehicles have obligation to drive via DOT scales.
Some scales have "no pickups" sign, so if you are less than 11,000 GVWR you can bypass it.
Hemi Joel
Minnesota
Posted: 04/09/21 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
A privately owned, privately used one ton should not have to comply with the same regulations that an over the road semi does, but unfortunately the laws have been misused to that effect. At the last renewal for my Ram 1 ton dually, they asked me if it is used for commercial, I said no, they gave me this new plate that states non-commercial. Hopefully it keeps the highway nazis away.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
