RV.Net Open Roads Forum: Class A Motorhomes: sewer odor
 > sewer odor
kemer
mn
Posted: 04/08/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
I've noticed with our motorhome that when I drive it for more than a couple hours, I tend to get strong odors from the black tank seeping into the coach. Not sure why, but here's my theory....When parked, any odors would go up thru the vent stack, but when driving(like 65mph), there would be a strong wind going across the opening of the vent. This might act like a lid preventing odors from escaping....Does this make any sense?
valhalla360
No paticular place.
Posted: 04/08/21 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Do take a look at the vent but normally there would be a venturi effect while driving, that pulls the odors out the vent.
A damaged vent could be negating that effect...or if there is a blockage, you might get odd airflow out of the tank.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
MountainAir05
New Mexico
Posted: 04/08/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Also you can put a water hose down the vent and ensure your flow of water is going into the tank. Need two people for this.
gbopp
The Keystone State
Posted: 04/08/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Could the odor be from a faulty air admittance valve(s) under the sink?
The odor from a gray tank can be just as nasty as a black tank.
schlep1967
Harrisburg, PA
Posted: 04/08/21 08:33am Link  |  Quote  |  Print  |  Notify Moderator
+1 on the faulty air admittance valve.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
midnightsadie
ohio
Posted: 04/08/21 08:48am Link  |  Quote  |  Print  |  Notify Moderator
mine was the seal on the commode.
fuzzyface
Polk City, FL
Posted: 04/08/21 09:19am Link  |  Quote  |  Print  |  Notify Moderator
My bathroom odor was from the clothes washer drain hose sticking into the pvc drain too far, displacing water in the 'P' trap. I raised the washer drain hose and fastened it to keep in out of the trap, and no more odors.
Linda and Mike Kruzin' in a Kountry Star
dougrainer
Carrolton, Texas
Posted: 04/08/21 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Put a Pint of Pine Sol in your Gray tank and then drive. If you get Pine Sol odor in transit it is your Gray tank. RARELY do you get foul odors from the Black tank, especially if you use the Black tank treatments as you need to do. GRAY water smells horrible. Make sure your Washer drain P trap has water in it if you have a washer. If you do not use the washer regularly, the water siphons out and that is a main source of gray odor in transit. Doug
ScottG
Bothell Wa.
Posted: 04/08/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure it's not the grey tank? As Doug indicated, it can smell horrendous. Sometimes the P-traps slosh and lose their seal. Try installing stoppers when traveling and see if the problem goes away.
Near DVNP, California
Posted: 04/08/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
"Also you can put a water hose down the vent"
That worked for me....did gray and black tanks.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
 > sewer odor
