RV.Net Open Roads Forum: General RVing Issues: Hot water trickle
 > Hot water trickle
Bob Vaughn
Seffner, Fl.
Posted: 04/08/21 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the issue. The cold water comes out with full force, The hot water starts at full force a couple seconds later it goes to a trickle in all 3 faucets.......something is amuck....I have tried every thing I can think of to no avail....what am I missing...check valves have been checked or replaced, all aerators all been cleaned....
PastorCharlie
NC
Posted: 04/08/21 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off heater, drain and flush. May be some scale stopping the flow as it leaves tank.
Bob Vaughn
Seffner, Fl.
Posted: 04/08/21 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
That has been done 3+ times already..
pinesman
virginia
Posted: 04/08/21 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Mine had a bad one way check valve when that happened
DrewE
Vermont
Posted: 04/08/21 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
Are your winterizing valves all fully set in the correct positions?
Bob Vaughn
Seffner, Fl.
Posted: 04/08/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Check valves have been replaced and unit has never been winterized..
capacitor
California
Posted: 04/08/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
When using on board water supply, turn on hot water, does pump turn on?
Bob Vaughn
Seffner, Fl.
Posted: 04/08/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Whether on city water or 12 volt pump the trickle is still there
ssthrd
Vancouver Island
Posted: 04/08/21 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
You could have a blocked line, a valve not wide open, or maybe a kinked pipe. Looks like you have checked everything else that comes to mind.
2014 Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax Anderson
DeeBee, JayBee, and Jed the Black Lab
Old-Biscuit
Verde Valley
Posted: 04/08/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
At all faucets or just one?
How long ago did you replace the WH Tank Hot Out Check Valve?
US NAVY------USS Decatur DDG31
 > Hot water trickle
