RV.Net Open Roads Forum: Tow Vehicles: Sports chassis and similar units becoming obsolete?
Search only in Tow Vehicles
 > Sports chassis and similar units becoming obsolete?
valhalla360
No paticular place.
Posted: 04/09/21 07:11am Link  |  Quote  |  Print  |  Notify Moderator
carringb wrote:
I think they'll make a come-back soon.
Biggest detractor is lack of a good 4x4 option. Any true MDT with 4x4 is too high for towing most 5th wheels.
Once somebody offers a series-hydrid powertain, front electric motors will make 4x4 (or really AWD, but in some ways this can perform better) feasible without raising the chassis-height.
Articulated transit buses already offer a similar powertrain. Diesel gens-set is mounted at the back. Rear and center axles are electric-powered.
I don't think 4x4 is really a factor. MDTs are usually towing monster 40ft+ 5th wheels...not many people drag those off road.
If you are thinking to go off roading once unhooked...a diesel dually 1 ton, is a lousy off road option. If you are into off roading, it usually means a toy hauler and the toys are used for off road play.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
2oldman
NM
Posted: 04/09/21 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I own one, and it's Sport Chassis, not Sports.
Air seats, air cab, air hitch, air shocks. And plenty of headroom. And you sit up high. And 22.5" tires roll smooth.
I will admit one annoyance.. I'm constantly battling air leaks. Nothing critical, but I wish someone could fix them for longer than 6 months.
* This post was edited 04/09/21 08:42am by 2oldman *
Cummins12V98
on the road
Posted: 04/09/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
When I bought my 11 DRW RAM I noticed about that same time many MD Trucks were for sale. Talked to one guy and he said as soon as it was sold he was buying something similar to my truck. He was having a hard time selling it, he said as many like him were doing the same.
Fact was these guys that wanted to to tow a heavy RV like mine had to go MD. Now for example I tow my 24k Mobile Suites at and under my trucks SAE numbers. If my RV was a triple axle I could tow much heavier.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Posted: 04/09/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
But any pickup is a far better choice as a daily driver or even a runaround vehicle when camper is parked. Nevermind the fact that the MDTs have stagnated in terms of power for the last however many years and any of the new diesels will destroy a MDT from a power standpoint.
Add in the ability to get well appointed class 4-5 trucks that have similar gearing and adequate rear axle capacity for the big trailers, and more power and more user friendly and less costly, it makes the MDT haulers an even more limited use, one trick pony.
But when I win the lottery, I'll still buy one to drive to the Home Depot....because I can!
Side note, buddy bought an older one, stretched the frame and nose and dropped a warmed up 400 Big Cam Cummins in it. Holeeee ballz!
It's a monster!
2017 Heartland Torque T29
aarondeere
Maryland
Posted: 04/09/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
It's a factor for me. While at this campground lakewood a fl106 got stuck in sand. Doesn't take much. Wet grass up a hill a little mud in a campsite.
Aaron
2010 Dodge 3500
2012 Voltage 3600 Epic
aarondeere
Maryland
Posted: 04/09/21 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Sorry sport chassis. Get use to air leaks. Winter time is the worst for me with the fittings shrinking. Have 2 fendt tractors that have air brakes and there is always something hissing a little. Mechanic says only worry when the leaks get big. Having all the air suspensions sure does sound like a nice ride though.
* This post was edited 04/09/21 11:50am by aarondeere *
2oldman
NM
Posted: 04/09/21 11:49am Link  |  Quote  |  Print  |  Notify Moderator
I have hydraulic brakes, which to some people is a total surprise. Some don't even believe me.
theoldwizard1
SE MI
Posted: 04/09/21 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
aarondeere wrote:
With this do you think the days of medium duty trucks are somewhat numbered?
Medium Duty/Class 6 and 7, (think F600, F650 and F750) are the back bone of local deliveries. Most have a medium to large "box" mounted on them. Many are made into dump trucks. Very few would have ever been used as RV chassis.
Personally, I am very surprised that these local fleets have not switched over to the Ford chassis with the new 7.3L gasoline engine. Lower initial cost and lower operating costs, admittedly at lower payload.
Some might call the Ford E450 a "medium duty", but it is really at the very bottom of that scale. The F550-F600 woul make a much better RV chassis Class C motorhome chassis, except for the height and no pass through from the drivers area to the living area.
carringb
Corvallis, OR
Posted: 04/09/21 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
F-series MDT 7.3 is production constrained right now. Order bank for 2021 is closed. That’s why you don’t see more.
2014 ORV really big trailer
2015 Ford Focus ST
JRscooby
Indepmo
Posted: 04/10/21 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Running off in the weeds here. Will that mechanic pay your fines? If the leak is big enough to hear, it can get you put OOS. There is a minimum amount of time the vehicle must hold pressure. I but hundreds of thousands of miles on old trucks. Fixed many a leak. Most times I fix one it never leaks again until part wears out.
