RV.Net Open Roads Forum: Tow Vehicles: Sports chassis and similar units becoming obsolete?
Search only in Tow Vehicles
 > Sports chassis and similar units becoming obsolete?
pitch
NY
Posted: 04/10/21 06:15am Link  |  Quote  |  Print  |  Notify Moderator
well he is not moving over 20MPH with his Fendt, 90% off the time probably between 8 and 12. I don't know what kind of fine he could get or who would issue it.
Normally the DOT cops don't patrol fields.
JRscooby
Indepmo
Posted: 04/10/21 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I misunderstood what kind of vehicle he had. But the advise to ignore leaks is bad advice. All air that is used or leaks must be replaced. More wear on compressor. Air in brings in moisture. And that will cause problems with the system.
2oldman
NM
Posted: 04/10/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
the advice to ignore leaks is bad advice.
In my opinion it is. I'm hauling a 5th wheel all over the US, and ignoring little problems is how they grow into big ones.
aarondeere
Maryland
Posted: 04/10/21 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Your right these are farm tractors and while german made with quality they do suffer from leaks with all the bouncing. They do go 34mph though. Lol Any air leaks on the road trucks brakes would be immediately addressed for safety and legal reasons. The leaks I was referring too and the other post was aggravated with deal with the seats and possibly the leveling valve which can leak at the fittings from time to time usually due to cold weather.
Aaron
2010 Dodge 3500
2012 Voltage 3600 Epic
JRscooby
Indepmo
Posted: 04/10/21 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Bouncing in a field? Is that worse than 500+ miles a day on a truck that is nearing the end of second million miles?
Seat; Make sure the lines clear, and dump pressure before you out. This keeps it from pushing you out the door, and keeps the line from pulling tight before it adjusts to the change in weight.
Fittings that are taped where the threads seal, not taped where the threads hold it together rarely leak if the lines are well supported.
Jarlaxle
New England
Posted: 04/11/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
spoon059 wrote:
Couple differences that I see...
That Freightliner will still have a substantial value in 10-15 years, the pickup won't.
Have you priced 10 year old diesel pickups lately?
That Freightliner has great comfort features like air-ride seats, can't get that in a pickup yet.
That's because you don't need them, since the pickup lacks the Freightliner's kidney-hammering ride.
That Freightliner likely doesn't even "need" trailer brakes, the pickup truck will need some sort of help slowing down at higher weights.
Yes, it does. Anyone driving without trailer brakes should be arrested.
But, for people that like bling, a new pickup truck offers lots of gadgets and gizmos and will haul decent weights with respectable power.
And much easier service, and VASTLY greater comfort, and probably better reliability, and is much more user-friendly when not hooked up. Also likely much cheaper to insure.
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. ">
Current rig:
1992 International Genesis school bus conversion
Jarlaxle
New England
Posted: 04/11/21 11:15am Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
I own one, and it's Sport Chassis, not Sports.
Air seats, air cab, air hitch, air shocks. And plenty of headroom. And you sit up high. And 22.5" tires roll smooth.
I will admit one annoyance.. I'm constantly battling air leaks. Nothing critical, but I wish someone could fix them for longer than 6 months.
It's a Freightliner...you get used to them.
Jarlaxle
New England
Posted: 04/11/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
carringb wrote:
F-series MDT 7.3 is production constrained right now. Order bank for 2021 is closed. That’s why you don’t see more.
I have seen a fair number of V10 F-650s. They seem popular as rollback wreckers.
2oldman
NM
Posted: 04/11/21 11:28am Link  |  Quote  |  Print  |  Notify Moderator
500 miles in one day and I'd have to be carried out of the truck.
spoon059
Just north of D.C.
Posted: 04/11/21 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Not if you were in a truck with air-ride seats. Those things are very comfortable and you don't feel "beat up" at the end of the day.
2015 Ram CTD
2015 Jayco 29QBS
