RV.Net Open Roads Forum: Truck Campers: Roadmaster or Hellwig
 > Roadmaster or Hellwig
Fishhunter
Alaska
Posted: 04/09/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Looking to install a sway bar on my Ram 3500. Which one would you recommend? Roadmaster or Hellwig Bigwig
2021Ram 3500 DRW Torklift Tiedowns, Fastguns
ORV 24RLS Titanium
2015 Adventurer 86FB
Slymer
Ontario, Canada
Posted: 04/09/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a stock sway bar on the front, and added a Bigwig on the back. I believe it has 3 settings. I had to call their cust. support once to get the best setting to use. On a Sunday afternoon, just before dinner I had a tech. on the first ring. Amazing,....knew his stuff too.
I am very happy with the product,....AND the service. I don't know anything about Roadmaster.
ScottG
Bothell Wa.
Posted: 04/09/21 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
If you go with the Hellwig, get the biggest one. I didn't and wish I would have.
Geo*Boy
Unknown
Posted: 04/09/21 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
The Roadmaster bar is 1-5/8” in diameter, won’t fit truck with air suspension.
BurbMan
Noblesville, IN
Posted: 04/10/21 05:49am Link  |  Quote  |  Print  |  Notify Moderator
I see you had a bigwig on the old truck, why are you considering a Roadmaster this time around? Also, I see you had StableLoads on the old truck, are you planning to put those on the new truck too?
I just ordered a set for my SRW and am excited to see what difference they make.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
otrfun
On The Road
Posted: 04/10/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
We chose the Roadmaster over the Hellwig for our Ram 3500 SRW because it mounted to the axle housing in a more outboard, OEM fashion, at the bottom of the shock mounts. The Hellwig mounts more inboard with a clamp around the axle making it less effective IMO. We also installed lower Stable Loads (stainless steel versions). They offered some improvement in sag, handling, and even reduced sway slightly (at highway speeds)—-nothing dramatic. They work especially well when used in conjunction with slightly pressurized airbags.
Fishhunter
Alaska
Posted: 04/10/21 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Just read some good reviews on the Roadmaster..I’m gonna wait till The new truck gets here and load up the TC and see how it handles as it is a DRW. My 2015 was a SRW and the sway bar made a lot of difference. Haven’t made up my mind on the Stableloads yet.
Fishhunter
Alaska
Posted: 04/10/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
No air suspension here...
BurbMan
Noblesville, IN
Posted: 04/11/21 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Ah OK, missed that you upgraded to a dually.
billsnp5
Nevada
Posted: 04/11/21 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
I've got a 2020 DRW with factory airbags and the Roadmaster will not work on it. Helwig does not have one yet for it but is working on one. It was suppose to be available end of March but I called last week and it is still in development.
2021 Host Cascade
2020 Ram Laramie 3500 DRW 4X4 Crew Cab Diesel
2013 Phoenix 721 Bass Boat
