RV.Net Open Roads Forum: Truck Campers: Palomino 1240 /F250 8' bed
 > Palomino 1240 /F250 8' bed
mcaruso
Michigan
Posted: 04/09/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Going to pick up a palomino 1240 to put in my brand new F250 long box. I'm new at this and have a few questions. Do I need to remove the tailgate? Currently it's in a short bed truck with the tailgate on obviously it down. The second is it a good idea to put down a bed mat? Like the ones they sell at Tractor Supply? Any help would be greatly appreciated heading out tomorrow morning.
Thank you
Monterey, California
Posted: 04/09/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
A bed mat is always a good idea IMO.
joerg68
St. Ingbert, Germany
Posted: 04/09/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Leave yor tailgate at home.
On the pictures of the 1240 I have seen, it has little side skirts wrapping around the truck's taillights.
If your camper doesn't have these and you are able to close the tailgate (which I personally doubt), you can still put it back on and see how you like it.
A rubber / stable mat under the camper is not a bad idea. I am sure more people will chime in.
notsobigjoe
southeast
Posted: 04/09/21 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely get the rubber mat it keeps things from sliding around. As far as your Palomino, good luck with it I have never seen one but I would think you would want to leave your tailgate home as it is another 70 pounds. Good luck fellow Truck camper and welcome!
cooldavidt
Vancouver
Posted: 04/09/21 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
I'd put a piece of structural closed cell foam on the floor. It comes in 4x8' sheets. I have 4" thick but that is my choice as I needed some height as I have lights on my cab roof.
Inexpensive and light weight. In a TC weight is important.
dhull
Some Lake Some where
Posted: 04/09/21 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
I tried the horse mat nice thick material. Weighs about 100 lbs. After wrestling that around a few times I bought a dee zee mat that Weighs about 30 lbs.
Bert the Welder
Van. Island
Posted: 04/09/21 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
I think a rubber mat is a good idea. Having gone with a 3/4" stall mat and struggled with it too, I think a thinner mat like the Dee Zee is a good start. And if you need more height, go for the structural rated foam sheets under the mat.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
Posted: 04/10/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Stall mats are not needed unless you need clearance. In which case, foam under a bed mat will accomplish the same or more and weigh less. Easy to figure if you have cab to overhead clearance before you go.
Yes get a bed mat.
Yes leave the tailgate home, you can decide later if you can or want to leave it on.
2017 Heartland Torque T29
