RV.Net Open Roads Forum: Truck Campers: 2008 Eagle Cap 855 in Canada
 > 2008 Eagle Cap 855 in Canada
hinterland
British Columbia
Posted: 04/09/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hi There, Just curious if anyone has this Eagle Cap? We are looking at it tomorrow to put on a 2014 GMC Duramax Crew Cab, Long Box, SRW.
It Just Doesn't Matter Who Owns the Grass Outside our Window!
OUR YOUTUBE CHANNEL
Bert the Welder
Van. Island
Posted: 04/09/21 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
3600-3800lbs loaded up. What's your truck rated to carry?
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
JimK-NY
NY
Posted: 04/10/21 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Not even close!!!!
The smallest EC has a dry weight of 3380. With propane and a full water tank the weight will be just shy of 3800#. That does not include options such as an A/C, awnings, generator, second battery or solar. Also add 1000# for cooking gear, bedding, towels, tools, air compressor, cleaning supplies, leveling blocks, lawn chairs, BBQ grill, food/drinks, clothing......
The smallest EC is likely to be in the 5000# range loaded for camping. When calculating gross weight don't forget to add the weight of passengers, stuff you might carry in the truck, tiedowns, fastguns, bed mat.....
You need a dually!!
hinterland
British Columbia
Posted: 04/10/21 06:36am Link  |  Quote  |  Print  |  Notify Moderator
This is the 2008 855, maybe built 3 years from 08 to 2010. It's 9'4" and the dry weight shows 2870 lbs and wet shows 3275 lbs
hinterland
British Columbia
Posted: 04/10/21 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Glove box sticker in the GMC says slide in camper max 3834 lbs
3 tons
NV.
Posted: 04/10/21 08:44am Link  |  Quote  |  Print  |  Notify Moderator
If it’s a 2008 it may have a full fiberglass front and rear caps...Make certain that the caulk has been kept up - caulk failure can lead to water intrusion that wont drain...
jaycocreek
Idaho
Posted: 04/10/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
The Eagle Cap 855 and the Arctic fox 865 have the same basic Floorplan and the weight won't be much different with an edge in weight to the AF 865...Nice Floorplan in my opinion that is coming back big time,in other truck campers..Wolf Creek and the Adventurer both with similar non slide Floorplans for those not wanting a slide out
3 tons
NV.
Posted: 04/10/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
My old EC Brochure does not show a 855 but does show a single slide rear wet bath 850 with an estimated wet weight of 3,155 (without options), and a 950 (long bed version of 850) at 3,320 wet...These weights are with the full fiberglass front and rear caps, and include elect. jacks but not awnings, batteries or generator...
Bert the Welder
Van. Island
Posted: 04/10/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Not even close!!!!
"Eagle Cap is reporting the estimated dry weight for the Model 855 at 2,870 pounds and the estimated wet weight at 3,275 pounds."-TCM 2008
-So like I said, given that manufacturers are stingy with their estimates, I ball-parked adding 800-1000lbs to their dry # since that seems to be the common weight added for "stuff".
So where did you get your weight number for a 2008?
Posted: 04/10/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
OP, don’t get sucked down the weight cop barrage here, but do be aware that you’ll need to upgrade your suspension.
2017 Heartland Torque T29
