RV.Net Open Roads Forum: Fifth-Wheels: Holding tanks
 > Holding tanks
RandandDoug
East Texas
Posted: 04/10/21 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
Bought a used 2019 Keystone Avalanche 321RS.
All company specs I have seen show it having 1 black and 1 grey tank.
There are two grey Pulls and one black. The salesman and I did a fairly quick walkthrough, my 3rd rv, and he explained that there are 2 grey tanks, and the that was that.
I am out today familiarizing myself with the trailer, flushing tanks and stuff, and it seems as though the bathroom sink is plumbed into the black tank, not sure about the shower yet, will be going back out to run some water through that too.
Is anyone here familiar with that? Seems strange to me, but I can live with it. Just curious and all the places to call are of course closed for the weekend.
Thanks
work2much
On the Road
Posted: 04/10/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty common for 5th wheels to have 2 grey tanks. One for the bath and one for the galley.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
ssthrd
Vancouver Island
Posted: 04/10/21 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
On my 2014 Laredo, there is a black (Right side) and a grey tank (Left side) between the frame rails directly under the toilet and the sink/shower. (Just repaired the grey [emoticon] ).
There is another grey under the galley sink.......... Not sure about the fresh water tank, but I assume it is beside the grey and on the left side.
The front tanks look to be the same size...........
Hope this helps. Good luck getting info from Keystone.
2014 Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax Anderson
DeeBee, JayBee, and Jed the Black Lab
agesilaus
North Florida
Posted: 04/10/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Dump some dye and water down the drains one at a time and see which valve shows the color
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
wildtoad
Blythewood, SC
Posted: 04/10/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Not uncommon for bathroom sink being plumbed to the black tank either due to ease of plumbing or to help assure sufficient water in the black to assure sufficient water to have things flow properly.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
TXiceman
Full Time RVer
Not all common to have two gray tanks, but some do. It is usually when the kitchen sink and shower are on opposite ends. The bathroom sink may be routed to the black tank since it is generally low use and the black needs lots of water to operate properly.
Ken
Amateur Radio Operator.
ssthrd
Vancouver Island
Posted: 04/10/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Good idea. Two different colors of food dye.
I forgot to say that both the shower and the bathroom sink go into the grey tank.
RandandDoug
East Texas
Posted: 04/10/21 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses. The labels at the pulls were wrong. Not sure why or how, but now I know so no problem. Not sure if it came like that or might have had some work done on it. And it does have two greys, but all the generic manuals and things online say one. I will be under it tomorrow, so maybe I will get some more surprises, but that's what's fun about this stuff, sometimes!! Haha
Roger10378
Goodrich, MI.
Posted: 04/10/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
When the bathroom and galley are on different levels they will have separate gray tanks. If they didn't it would be easy to overfill the tank and it would leak out of the one on the lower level while you didn't realize it and keep using the one in the upper level.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
RickLight
Washington
Posted: 04/10/21 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
I think it's not so much different levels as the distance between drains.
The general rule is 1/4" drop per 12" run. If the drains are too far apart then they can't connect to the same outlet. Mine are about 20' apart, so 5" drop!
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
 > Holding tanks
