RV.Net Open Roads Forum: Fifth-Wheels: BAttery replacement.
 > BAttery replacement.
grizz272
frozen tundra, WI
Posted: 04/12/21 04:18am Link  |  Quote  |  Print  |  Notify Moderator
How often do you replace the fifth-wheel dual batteries.
This will be the fourth yr for out camper. In previous campers I was never able to get more that 2 yrs before I replaced the original dealer batteries.
What is the go to battery for a fifth-wheel?
dmck413
Fluvanna Va
Posted: 04/12/21 05:01am Link  |  Quote  |  Print  |  Notify Moderator
I went to golf cart batteries and have been satisfied.Wish I could afford Lifepo batteries.
ndrorder
Southwest
Posted: 04/12/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Lifespan depends on the battery and technology. 5 to 6 years is typical for a well cared for battery. Some go longer. Some last shorter. An electrolyte tester is the best way to determine the health of a battery. AGM and maintenance free batteries are difficult to test.
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
MFL
Midwest
Posted: 04/12/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
How you use the battery, care for the battery, type of converter/charger, will all make a difference on battery life.
I purchased my current FW new 8/15/2012, at which time a single Interstate RV/Marine battery was installed. It is still in great shape, works like new. I only had to add water one time, after using a different charger, while battery was stored for Winter. That was five years ago, and water in battery is right where it should be last week, when I installed it back in my FW.
Jerry
TXiceman
Full Time RVer
Posted: 04/12/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Wet cell batteries typically will go 5 to 6 years if you do not abuse them and maintain them properly.
Ken
Amateur Radio Operator.
work2much
On the Road
Posted: 04/12/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Most FLA or AGM batteries have shortened lifespans due to over discharge, lack of full and complete regular charging or poor maintenance. The stock converter chargers in many RV's don't do a great job getting batteries to 100% and many don't do equalization charges. In addition the standard battery monitors give poor information as to state of charge so you are basically guessing leading to the batteries easily becoming discharged too low.
If you want a battery that will last many years go with lithium and also install a true shunt based battery monitor.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
morley
British Columbia
Posted: 04/12/21 10:31am Link  |  Quote  |  Print  |  Notify Moderator
I use 2 Trojan T-105’s and they perform well for 6 to 7 years if treated properly and you have a good converter.
2008 Topaz F254SS 26 ft.
2009 Chevy Silverado, 2500HD, Duramax, Allison Tranny, 4x4, EC
250 watt solar panel system, BlueSky controller and remote
Cambria, California area
Posted: 04/12/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I replace at 4 1/2 to 5 years. Just don't want a problem away from home.
Sandia Man
Rio Rancho, NM
Posted: 04/12/21 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Any of the batteries we received from the dealer were 12 volt car, or at best a so called hybrid RV battery. In either case they just can't deal with being drawn down time and again if you do lots of RVing off the power grid. If you mostly camp hooked up to a power pedestal any type of battery would suffice. Since we most often attempt to boondock or drycamp we found golfcart batteries give more bang for the buck. We purchase our GC2 6 volt batteries from Samsclub, we use a smart charging converter or inverter charger to keep them happy.
time2roll
Posted: 04/12/21 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
10 years on my 4x Costco GC2. Might be trading them early for a home built LFP later this year.
I only expected the included with purchase battery to get me home [emoticon]
675w Solar pictures back up
