RV.Net Open Roads Forum: Fifth-Wheels: BAttery replacement.
 > BAttery replacement.
pianotuna
Regina, SK, Canada
Posted: 04/12/21 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
If the bank is meeting your needs why replace it?
Regards, Don
grizz272
frozen tundra, WI
Posted: 04/12/21 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
I picked the fifthwheel up from the dealer today. They did some work in March and left the battery disconnect on. Well when they brought the camper out the batteries were completely dead. As in no power and not even a light would work.
The dealer plugged the camper in and after about 1/2 hr there was enough power the landing gear would raise the camper up high enough I could hitch up. By the time I arrived home there was a 1/4 charge showing. That is the first time that I know of that the batteries were completely dead. We do boondock and have had the batteries get low before but never dead. They are maintenance free batteries. So I can't check water levels.
I generally try to replace stuff like batteries and tires before they fail.
MNRon
Tennessee
Posted: 04/13/21 05:28am Link  |  Quote  |  Print  |  Notify Moderator
As others have said, how you care for your batteries has a lot to do with longevity. If you drain them well below 50% SOC, they won't last as long (FLA and AGM). If your charger isn't a 'smart' charger, they won't last as long. If you use regular 'car' batteries, they won't last as long.
You can get good FLA from Sam's or Costco for about $1/AHr (6v GC, had on last 5er), I'd expect those to last 5-6yr+ if treated well. For about $3/AHr you can get Lifeline AGMs (no maintenance hassle, have on current 5er); expect those to last 10+yrs if treated well. Li batteries are lighter and can be discharged further without harm but also have some special charging requirements. I don't have experience with these *yet* but price keeps coming down, and is below $10/AHr now.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
RambleOnNW
Pacific Northwest
Posted: 05/03/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
I got 9 years out of a pair of Sears DieHard Platinum AGM 12V marine batteries. Now on 2nd year with BatteriesPlus X2Power AGM batteries with 4 year full replacement warranty. Batteries are made by Northstar. I use a 4-stage charger by Progressive Dynamics. Good battery price, they had a $30 mail in rebate per battery plus a 10% online ordering discount.
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
Thermoguy
Graham, WA
Posted: 05/03/21 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a meter? Test them - charge them, then check every few days with no load to see if they are depleting. Then if that is good, put a small load on them and check to see if they are depleting too fast. If they are not holding a good charge, you should replace them if you want them to be reliable. You boondock, do you have a generator?
