RV.Net Open Roads Forum: Tow Vehicles: Real life Hybrid towing experiences
Search only in Tow Vehicles
 > Real life Hybrid towing experiences
philh
Belleville MI
Posted: 04/14/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
alexleblanc wrote:
i would shy away from any hybrid with a CVT for towing purposes.
If its rated for towing and you stay within that rating, towing with it is fine.
carringb
Corvallis, OR
Posted: 04/14/21 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
But also consider the ratings aren’t apples to apples. The Highlander Hybrid is not SAE J2807 certified and the owners manual states that towing in weather above 85F may cause overheating.
2014 ORV really big trailer
2015 Ford Focus ST
jonaz
Posted: 04/25/21 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
I towed a 3000 lb hybrid Kiwi trailer with a 2003 Honda Pilot 4wd. It was a great towing experience, even though I was extremely hard on the Pilot. It did everything I asked of it, and more.
[blue]2007 Dodge Ram 1500 4x4 5.7 Hemi (3.92 gears) Prodigy brake controller,Weight Distribution Hitch 2021 Coachman Catalina 263BHSCK
Note: Due to invalid formatting, all formatting has been ignored.
FWC
The Wilderness
Posted: 04/25/21 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
We towed a 13' Scamp (~2000lb) across the US with Hybrid Highlander and it was fine, no issues with either handling or power. I am not sure how the fuel economy was towing relative to a non-hybrid, but that is not really that important as the Highlander is a daily driver and was only used to tow < 10% of the time.
With a small trailer you will be fine with a hybrid. Also it sounds like this will primarily be a daily driver, and an occasional tow vehicle. Get what works best for you as a daily driver (ie not a pickup truck).
bikendan
Camano Island, Wash.
Posted: 04/26/21 02:03am Link  |  Quote  |  Print  |  Notify Moderator
the OP is asking about a hybrid TOW VEHICLE, not a hybrid TT.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Posted: 04/26/21 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I’m sure you’re right that they will actually pull the rated weight if they’re rated for it. And they may even do it for a while.
But the very nature of a cvt compared to modern automatics is like old autos that didn’t lock the converter compared to manual transmissions. More heat = no bueno.
* This post was last edited 05/25/21 06:40am by an administrator/moderator *   View edit history
2017 Heartland Torque T29
Sjm9911
New Jersey
Posted: 04/26/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
I never towed with one, but i will say i would not get anything that limits me to 3500 lbs towing. I have had pop ups and some can be heavy, especially after adding in all the aftermarket stuff. Do hybrids come with tow packages? If so, I would get the best small hybrid that has the best ratings. Have fun, if the rear sags, you can add air bags or bump stops. Some of the smaller campers ( mostly pups) cant use wdh.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
carringb
Corvallis, OR
Posted: 04/27/21 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Some hybrids can be charged.
The Lincoln Aviator Hybrid is a plug-in hybrid. It makes 494 hp and 630 ft-lbs of torque. Plugging it in give you 21 miles all-electric range. It can simply be plugged in to a campground pedestal. And it still tows 5,600 pounds.
* This post was edited 05/27/21 05:34pm by an administrator/moderator *
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 04/27/21 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Yes, but there's no pedestal when boondocking, so.......
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
carringb
Corvallis, OR
Posted: 04/27/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
So then you just drive. Even plug-in hybrids don’t require plugging in. It simply provides all electric range and also increases overall fuel economy.
