RV.Net Open Roads Forum: Camco Trailer Aid did not aid at all
 > Camco Trailer Aid did not aid at all
lwbfl
Florida Panhandle
Posted: 04/13/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
I ordered Goodyear tires for the Apex, decided I'd take the wheels / Castle Rocks off myself and take them to the shop. Pulled up on the Camco Trailer Aid and the tire didn't lift any at all. The shackles simply transferred the weight to the tire on the ground. So after 30 minutes of prep unhooking everything, swapping hitches, hooking up, moving twice, removing RV hitch from truck....I got out the trusty jacks and two spare tires. 30 minutes later I was done removing all four tires the old fashioned way. One spare on each side, one jack under the front springs. Sometimes it pays to trust your instincts and not the sales pitch LOL!
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
dodge guy
Bartlett IL
Posted: 04/13/21 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yep. Those only work on the torsion type axles.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Atlee
Mechanicsville, VA
Posted: 04/13/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
The Trailer Aid Plus I have worked on my 2017 Jayco Jay Flight 23RB. It had 3500# tandem axles. They definitely were not Torsion axles.
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
lwbfl
Florida Panhandle
Posted: 04/13/21 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure about that, the ad literally shows leaf springs like my setup. According to the manufacture, I need the extra 1.5 inches from the "plus" model and a flat tire LOL!
kellem
Shenandoah valley,VA
Posted: 04/13/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Well I have both incase the other is just hype.
Bobbo
Wherever I park
Posted: 04/13/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
The one time I have ever used mine, (I had the "plus" model), it got the wheel with the flat (actually shredded) tire up high enough to remove the wheel. It was not high enough to put a good tire on until I put a standard car jack under the axle and raised it a few inches.
Bobbo and Lin
lwbfl
Florida Panhandle
Posted: 04/13/21 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
That's pretty much what the rep said would happen.
JIMNLIN
Oklahoma
Posted: 04/13/21 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Bet'cher glad you weren't on the road in DFW rush hour traffic and had a flat tire on I-35 inner loop....or on a dark and lonely state hiway 52 miles from the nearest small town. Pre ops required before hitting the road.
Lantley
Ellicott City, Maryland
Posted: 04/13/21 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
This is why it is a good idea to do a tire change test to ensure you have the correct equipment and the correct approach to changing a tire on the road.
It's all fun and games in your driveway. But on the side of the interstate is no time to find out your not properly prepared/equipped
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
GrandpaKip
Flat Rock
Posted: 04/14/21 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I’ve used the Trailer Aid several times and had no problem. Standard 3500# axles. Others have reported it doesn’t lift high enough, also. Maybe it’s the spring packs, equalizers, or space between tires.
As stated, it is best to try your system at home first.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
