RV.Net Open Roads Forum: Camco Trailer Aid did not aid at all
 > Camco Trailer Aid did not aid at all
MFL
Midwest
Posted: 04/14/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
I also think the space between the tires can make a big difference. My TA plus works very well with both spring system, and torsion.
Jerry
Hondavalk
Toledo
Posted: 04/14/21 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Tire spacing is why it works on my horse trailer but not the wide stance axles on my TT
lwbfl
Florida Panhandle
Posted: 04/14/21 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
I've listed it for sale on Marketplace and will just use my floor jack. It barely took 15 minutes to change out the spare today. Anyway, I have the GYs installed and noticed they have an extra ply in the tread and are significantly more heavy than the Castle Rocks. The tech commented several times about the weight of the GYs. And to many comments here and abroad, yes it is best to test in the comfort of home and not during a true emergency. That's why we yard camp so much!
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
JRscooby
Indepmo
Posted: 04/14/21 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
And to many comments here and abroad, yes it is best to test in the comfort of home and not during a true emergency. !
IMHO, the main issue with carrying a floor jack is most times you need it other than home you are missing a very important part to make it work safely; a floor.
lwbfl
Florida Panhandle
Posted: 04/14/21 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
It's all I've carried for 30+ years. A 2x6 goes along with it. Until two years ago I never had anything but dirt and grass to work in so I'm well equipped for that LOL!
JRscooby
Indepmo
Posted: 04/14/21 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you can haul the floor too. But it takes more thought about where to put the board than bottle jack. More danger of falling, but less likely to be under when falls
lwbfl
Florida Panhandle
Posted: 04/14/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't everyone carry tools in their truck? I have multiple boards in the toolbox. I've used this jack with everything from a F250 with a 16" lift to Airstreams, Pop-Ups, utility trailers, etc. Never had a problem so far. You just have to use common sense (a super power these days) and be smarter than what you're working with.
Sjm9911
New Jersey
Posted: 04/14/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
I will agree, carry extra cribbing. My trailor aid works fine, if you need another 1/2 inch put a board under it. Or use the bottle jack or whatever else you want to carry with you. Sometimes you need more then one thing to accomplish your goals.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
lwbfl
Florida Panhandle
Posted: 04/14/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
My issue was the higher I lift one tire, the more it pushes the other one down. I would have had to jack the tire up about 6" to get it off the ground with the rear axle on the aid. With the shackles hooked together, they can actually flip down quite a distance! With both on the ground I lifted it 2" and changed them with ease. I'm not sure how much higher I'd have to get one tire before the other finally cleared the ground but it would be a significant angle an I'd rather just use the jack to lift the tire 2" and let the TT stay level.
Sjm9911
New Jersey
Posted: 04/14/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Just looked at a picture of what i think was your set up, maybe the extra height alows the axels to move more. Works on mine, but everyone is diffrent. I do also carry 2 bottle jacks and the tv jack and a 2nd spare. I dont want to get stuck. Ever. Wood is good for a base , or a hill also. I learned that with just my truck long ago. You do you!
