RV.Net Open Roads Forum: Truck Campers: Solar charge controller confusion
 > Solar charge controller confusion
Hemi Joel
Minnesota
Posted: 04/19/21 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't change the way the SCC is wired. It's a waste of time and energy. Either way, the power from the SCC gets to the load and to the battery. They got the wires to fit in the holes, so what's the problem? You said "it's independently fused in the back" What is independently fused? The solar panel to SCC, the SCC to fuse panel, or fuse panel to battery? I agree with fixing the exposed conductor. Maybe trim off the frayed ends that didn't make it into the hole.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
