RV.Net Open Roads Forum: Travel Trailers: Misplaced Keys
 > Misplaced Keys
MFL
Midwest
Posted: 04/14/21 04:39am Link  |  Quote  |  Print  |  Notify Moderator
If you are near a trailer dealer, you may check to see if they will loan some keys to you to try. I think these cheap RV locks are similar, even the dead bolts. I had a key on my truck ring, I thought was for my FW, and used it to easily open the double locked door. When I grabbed the camper keys later, which has 2 separate keys for the door, and of course the 751 baggage key, I realized the key I used earlier, was for the side RV type door on my enclosed snowmobile trailer. Comparing the keys, pretty similar.
You just need a key from a dealer that works well, copy it, buy it from dealer, if an extra.
Jerry
ZINGERLITE
Union Lake, MI
Posted: 04/14/21 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
I think the latch is universal but the dead bolt is not. When i dropped mine off for warranty work a few years ago they had me lock the handle but unlock the dead bolt. Even though it was the same key? they said that they had a master key for the handle but the dead bolt was more specific.
But it sounds like both are locked so i can't offer much help. definitely get a spare set once you get it unlocked.
MFL
Midwest
Posted: 04/14/21 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Zinger...I agree, the deadbolt lock a slight bit better than universal, but if you read my first post, my other trailer key worked easily in the handle, and dead bolt lock.
I might add that the keys for my FW door locks are slightly different, but the dead bolt key, works easily for both. Yes, my FW dead bolt key, easily unlocks my snowmobile trailer door, both handle and dead bolt.
Most RV locks are of cheap design, and many keys will interchange.
Jerry
bgum
South Louisiana
Posted: 04/14/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
At one time in the 1960s Oldsmobile only made 7 -8 different key combinations for all its cars. This also applies to your lock.
Monterey, California
Posted: 04/14/21 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Locksmiths have so many tricks...scary!
afidel
Cleveland
Posted: 04/14/21 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Well, Global Link has 90 key combinations for RVs and then there are at least 7 other manufacturers of RV locks, so there's a lot of potential keys to check.
As far as picking, if they're global link it's going to be quite difficult because they have both top and bottom pins.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
Posted: 04/14/21 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
After trying every other key ya own, in case one might work, does it have a typical escape window? The one with the little bar that locks it or props it open. You might? be able to slim Jim into that window and pop the bar up in which case you could crawl into it.
2017 Heartland Torque T29
Fisherman
Angus, Ontario, Canada
Posted: 04/14/21 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
bguy wrote:
Well I guess it was bound to happen sooner or later with only one set of keys. Misplaced and of course she's all closed up for the winter with the door handles and deadbolts locked as well as the hatches. Any non destructive suggestions? I'm pretty sure the keys will turn up but DW wants something out of the trailer.
Thanks for looking.
Well that's what happens when you rely on one set of keys. Why don't you have a spare set that stays in the tow vehicle. I do, for boat and ATV and travel trailer.
philh
Belleville MI
Posted: 04/14/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
electronic locks can be your friend [emoticon]
Trailer keys stay in the truck, which has a keypad on the outside.
Reader1
Ohio
Posted: 04/14/21 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Until I had the remote lock thing, I could not be trusted with keys. I have a regrettable history! To avoid any issues, we have an extra set of truck keys in the camper and an extra camper key in the truck.
 > Misplaced Keys
