RV.Net Open Roads Forum: Arctic Fox 1150 is breaking my 2016 Ford 350 dually
 > Arctic Fox 1150 is breaking my 2016 Ford 350 dually
Page of 11
Avid Fox
On the road often.
Posted: 04/14/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
JTLance wrote:
09 Lance 1191
21 Lance 1172
My 07 3500 DRW, Classic, LBZ has always either had a 5th wheel or two heavy campers on it. Airbags to get camper JUST off overloads, Torklift frame tie downs, Torklift StableLoads.
Looks fine and no cracks!
Maybe its HOW you supported the camper vs poor bed construction...
HOW it's supported? It has an extra leaf in back and Torklift wedges. What other choice is there on an f350?
Kayteg1
California > Nevada
Posted: 04/14/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
So how about the picture for rear bed support?
Avid Fox
On the road often.
Posted: 04/14/21 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Support or attachment? Rear of camper is attached to bumper. Not much strain there though. Rears ties are solid but kept just barely snug. Fronts are on tension springs.
Avid Fox
On the road often.
Posted: 04/14/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1
California > Nevada
Posted: 04/14/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Bed support. You need to go under.
Seeing your strong bumper I would consider putting some shims on it to support the camper.
mellow
Salisbury, MD
Posted: 04/14/21 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Surprised the tag axle guy hasn't posted about how he can solve this.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
mellow
Salisbury, MD
Posted: 04/14/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Torklift puts the blame on HJ for this damage: https://www.torklift.com/index.php/blog/........eventing-bed-damage-from-my-truck-camper
jshupe
FT
Posted: 04/14/21 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Seems pretty obvious to me that the small pieces they use to tie into the frame are insufficient to prevent this sort of damage. ¯\_(?)_/¯
2019 Ram 3500 HO/AISIN CCLB DRW Longhorn
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
Kayteg1
California > Nevada
Where?
All I can see is TL comment
TL wrote:
It is important to recognize that pickup trucks are now built from thinner metals and truck campers are increasing in size.
So they indicate the installer education is a factor.
Nothing wrong with the design for what it was design for.
jshupe
FT
Posted: 04/14/21 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
Where?
Although there are small metal parts with this type of tie down that come into contact with the trucks heavy-duty frame, the contact is incidental and lends negligible support as the primary strength. The support for this type of tie down is the truck bed and rear bumper and not the truck’s frame.
Negative side effects from bed-mounted designs are lack of support and potential for damage to your truck bed.
Page of 11
