RV.Net Open Roads Forum: Arctic Fox 1150 is breaking my 2016 Ford 350 dually
 > Arctic Fox 1150 is breaking my 2016 Ford 350 dually
Page of 11
Lockport
Michigan
Posted: 04/18/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
I see I forgot we’ve had our current camper on TWO F350 trucks. First one is 2000 long bed, SRW. That truck has 200,000 miles now, hauled lighter camper then 9 years/25,000 miles of Snow River. Bed on that truck is fine,we still have that one- had frame tie downs. On 2016 have Tork Lift and Fastguns. Camper on 2016 now, waiting to see if Canada will let us in this summer!
StirCrazy
Kamloops, BC, Canada
Posted: 04/18/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
Torklift article sounds like written by 3rd grader.
They talk about "bed frame"
Have never seen such animal.
All truck beds I have seen are resting on truck frame.
Somebody missed his classes.
go look under your truck, there is the bed resting on a subframe (or crossmembers if you like) that is on the truck frame.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Kayteg1
California > Nevada
Posted: 04/18/21 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Steve
Sounds like we are saying the same thing?
Only I don't consider cross members a frame.
Avid Fox
On the road often.
Posted: 04/18/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
I don't either...
As the OP here, thanks for all the input. Some good and thoughtful as usual for this type of forum, some off base also as usual, but all interesting all the same.
Going on a trip next week. I'll follow up after some mods.
Cheers.
3 tons
NV.
Posted: 04/18/21 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Aluminum is kinda brittle and has no grain...Makes me kinda wonder if this would've happened with a steel bed - I donno??
3 tons
rickjo
SW New Mexico
Posted: 04/18/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
Nope. I do know. Read my earlier post on this thread.
rick
2019 F-350 4WD Crew Cab DRW 6.2 l gas engine (6500 lbs cargo capacity!)
2007 LanceMax 1181 loaded, King memory foam mattress (driver's side locker omitted).
"Leave the trail a little better than you found it."
Hemi Joel
Minnesota
Posted: 04/19/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
The newer trucks are made of tin foil. I have a 2017 ram that dents if you breathe on it. That's one of the reasons why I'm sticking with my old 93 one ton.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
brholt
Seattle
Posted: 04/19/21 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
I will take a look at the bed on my 2013 DRW next time I take the camper off, in a week or so. I’ I haven’t seen any issues with the bed or frame. I do see a fair amount of “flex” and I have always had “creaking” sounds with the windows down at low speeds on some “bumps” over the 9 years as I have carried a 1150. I have always assumed they were normal and have never been able to figure out where they are coming from. .
Avid Fox
On the road often.
Posted: 04/19/21 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you. This is the kind of thing you can look for, but maybe they're just made this way. IDK. The bed rails are show similar crowning. But no obvious stress buckles. It's odd. I'm thinking they are this way from new in that model.
Doesn't explain the stress cracks at the rear, but the crowning is another issue that allows for too much rocking. Argh.
mellow
Salisbury, MD
Posted: 04/20/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Not hard to switch out beds in these trucks if it gets to that point. The longest part is getting out the bolts that hold it down to the frame if they are rusted. Took me about 3 hours to get my bed off, but that was due to having to cut the bolts off. Putting the new bed on with a lift took about an hour, this is for a DRW.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
Page of 11
