RV.Net Open Roads Forum: Towing: WD Hitch or not?
Search only in Towing
Open Roads Forum  >  Towing
 > WD Hitch or not?
Drew A.
Massachusetts
Posted: 04/14/21 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Greetings,
I am towing a 26' 7000 pound gross travel trailer with my 2018 Ram 3500 CC SB truck. Do I need a weight distributing hitch with this combo?
The Ram manual states the max tongue weight for 2500/3500 trucks is 1800 pounds but does not say if that is with/without WD. There is no mention of WD in the manual except for the section about how to adjust spring bar tension.
Thoughts?
-Drew
2018 Ram 3500 CTD, 4X4, Laramie, SRW, SB
2021 Imagine XLS 22MLE
BurbMan
Noblesville, IN
Posted: 04/14/21 06:05am Link  |  Quote  |  Print  |  Notify Moderator
The easy answer is....it depends. Assuming you don't pack the truck with heavy stuff, the tongue weight of the trailer by itself is probably not enough to make the truck sag. WD hitches also provide some level of sway control, so there's benefit there even if you don't need it to level the rig.
If you're towing without a WD hitch now and not having any issues, then there's your answer. If you are having issues, then there's your other answer....
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Drew A.
Massachusetts
Posted: 04/14/21 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input. I have only towed it once: 3 hours home from the dealer. The trailer was completely empty as was the truck. With this trailer having a rear kitchen, I was concerned it might sway due to low tongue weight.
On the trip home, I used a standard WD hitch with 1200 pound bars and no sway control. The tow was great with no sway at all.
BenK
SF BayArea
Posted: 04/14/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
There should be a ratings label on the reciever that will have a 'dead weight rating' and a 'WD weight rating'
Found this image below on rv.net
Dead weight or weight carrying = no WD system
-Ben Picture of my rig
Near DVNP, California
Posted: 04/14/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
That maximum tongue weight isn’t impressive.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
valhalla360
No paticular place.
Posted: 04/14/21 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Need? Not in the absolute sense.
A good idea? Yes. Especially if you already have a WDH.
Note: a WDH won't fix a hitch weight that is too low. Redistribute the weight so it's at least 10% and preferably 12-15%.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Boomerweps
Hills of PA
Posted: 04/14/21 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Not at all. My SIL used a Ram 2500 diesel to tow his 8000# toy hauler, no WDH, no probs.
Sold the truck for a new 2500 gas about a year ago.
A 3500 with a 7000# TT, no problem.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
Posted: 04/14/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
There’s not.
And the 2.5” Ram hitches are rated 1800/18000lbs weight bearing, fwiw.
2017 Heartland Torque T29
Posted: 04/14/21 09:04am Link  |  Quote  |  Print  |  Notify Moderator
OP, all trailers handle a bit different.
From a capacity standpoint on the truck, you don’t need anything extra.
From a handling and comfort standpoint you may want or need wd or sway control.
Just test it out and decide for yourself what the best setup is for you and your trailer. Truck won’t care either way with a trailer that light.
Yosemite Sam1
Under the pines.
Posted: 04/14/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Everyone who is in the know said I don't need one because of the match between my trailer puller and the weight of the RV.
But heck, it's worth the peace of mind and the feeling (I might only be imagining it) of day-and-night difference in stability.
I also have this unease of all that weight and movements hanging just on that tiny balls, lol.
 > WD Hitch or not?
