RV.Net Open Roads Forum: Fifth-Wheels: Can't find my water pump
 > Can't find my water pump
Memphisdoug
Memphis, Michigan
Posted: 04/15/21 10:49am Link  |  Quote  |  Print  |  Notify Moderator
On my last 2 5th wheels the pump was accessed from the basement storage. On my Laredo I had to unscrew a panel on the back wall of the basement to reach the pump. That was on the passenger side. On my current trailer, the pump is accessed by a door on the back side wall of the basement.
2006 Silverado 3500 Crew Cab
2006 Crossroads Paradise Pointe 36RL
topjimmy
Washington Coast
Posted: 04/15/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
In all my Montana's it is behind the convenience center where the shower dump valves etc.. take out the false wall and there it is
2015 Montana 3735MK Legacy,2007 3500HD GMC Dually LBZ Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
Limit4
Festus Missouri USA
Posted: 04/15/21 11:27am Link  |  Quote  |  Print  |  Notify Moderator
If there is a removable panel under the oven take a look. That is where ours is.
rlw999
Washington State
Posted: 04/15/21 11:50am Link  |  Quote  |  Print  |  Notify Moderator
So sounds like the rule of thumb is "The pump should be close to the freshwater tank. Or not." and "The pump should be close to the water heater. Or not." and "The pump should be near the kitchen. Or not.".
Or in other words, until you find it, you won't know where it is, different RV's put it in much different places.
lwbfl
Florida Panhandle
Posted: 04/15/21 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
So true! I've had 8 now and they were all different. I've always found them by accident or followed the noise. They put them in some strange places sometimes! The Airstream was the worst! 31' Rear bath, fresh water tank in the rear bumper / storage area behind the tub. Kitchen was 3/4 ways to the front, then a pretty large living area. The pump was in the very front under the couch. 25' from the tank and bathroom and 5' outside the kitchen!
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
