RV.Net Open Roads Forum: Towing: 5th wheel tailgate
Search only in Towing
Open Roads Forum  >  Towing
 > 5th wheel tailgate
Whiskey River
Pittsburgh, Pa
Posted: 04/15/21 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Any recommendations out there for a 5th wheel tailgate. I am going to get one as I got the Anderson hitch and when backing in with the tail gate down it is very close to the rig.
I have an 08 Dodge Ram w/ Regular cab & 8' bed
Super_Dave
Harrisville, UT
Posted: 04/15/21 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I was in the very same situation. Be careful to look at the weight limits of the various 5th wheel tailgates. Many of the cheap ones are limited to 100 pounds. I went with one rated for 200 pounds and I can at least stand on it briefly.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
WNYBob
Tonawanda, NY
Posted: 04/15/21 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Maybe something like this will work for you.
Tailgate @ eTrailer
pinesman
virginia
Posted: 04/15/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
I have been happy with Custom Flow
Super_Dave
Harrisville, UT
Posted: 04/15/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
I really liked the looks of the Husky Liner tailgates but couldn't find them in stock so also went with the custom flow. Other than scratching easily, it does the job.
Super_Dave
Harrisville, UT
Posted: 04/15/21 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Tailgate @ eTrailer
I believe that this is one of the 100 pound weight capacity tailgates
wanderingbob
monticeeo, fla
Posted: 04/20/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
I cut a piece of plywood the correct size and spent the money that I saved on Diet Pepsi or some other beverage .
Super_Dave
Harrisville, UT
Posted: 04/20/21 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
3/4" plywood was $100/sheet at Home Depot last week. Not a lot of savings for a hillbilly tailgate.
Whiskey River
Pittsburgh, Pa
Posted: 04/21/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
OK Thanks all. Still looking, but I have to get one.
I moved the 5er yesterday and I have to back under, then put the tail gate back up and continue to back under the rig. Its just to close to the 5er with the tail gate down. If not square with the rig, it will hit for sure.
The Anderson hitch is not like the typical 5er hitch that you have to just get close and back up and it goes into the latch. Anderson is a goose neck ball. But it only weighs 40 pounds and says it is good for 20,000# and 4500# on the pin. So weighing only 40 pounds its easy to take out of the truck and store. Don't need 3 men & a boy to remove it...
rhagfo
Portland, OR
Posted: 04/21/21 07:15am Link  |  Quote  |  Print  |  Notify Moderator
I had a Custom Flow on the 2001 Ram just as strong as the OEM. With the 2016 Ram I don’t want to loose the backup camera.
