RV.Net Open Roads Forum: Tow Vehicles: Cummins/Tula dDSF (diesel Dynamic Skip Fire)
Search only in Tow Vehicles
 > Cummins/Tula dDSF (diesel Dynamic Skip Fire)
ShinerBock
LVTX
Posted: 04/16/21 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Groover wrote:
ShinerBock wrote:
Groover wrote:
If the 4.5l engine is expected to do the work of a 6.7l it will be interesting to read what they did to ensure long life.
The 4.5L is pushing a 175kW(234 mechanical horsepower) electric motor in a hybrid setup so it is not primarily the diesel engine that is doing the work. Very similar to a diesel-electric train setup.
But all of the power still originates with the diesel engine unless there is a plug in battery pack that I am missing.
Yes, there is a battery. It is in the technical drawings in the link that I posted.
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
stsmark
Northern CA
Posted: 04/17/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
It’s very similar to the Hyllion ERX. They’re using CNG for the generator fuel. Dana is their partner on the drive axle/ motor.
BenK
SF BayArea
Posted: 04/17/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
RoyJ....ditto...that chart is almost exactly what PWM looks like from experience in Industrial Motor Controls
Add that today's computer systems & injector systems are fast enough to keep the combustion chamber at the diesel stoichiometric air-fuel ratio 14.5:1 and even leaner in other parts of the CC
Am guessing so much leaner to get as complete a burn as can...that NoX might become an even higher issue(s)
RoyJ wrote:
Both real exciting technologies in the diesel front. The Skip Fire is almost like PWM for electric motors, and may be the big step we're waiting for in in-cylinder emissions control vs relying solely on after-treatment. Hopefully 1 day we can look back at the past 15 years as a "interim" emissions phase, much like gas engines of the 70s and 80s.
I've been saying for years we should look at series hybrids used on trains (GE's AC-AC drives can hit 90+% efficiency). It's much easier to optimize your prime mover for a few set-points, than a 3-D map of rpm vs throttle position.
With a battery, we can't use pure AC-AC of course. But a battery is also necessary because unlike a locomotive, we need more than 8 throttle settings, and also need instant response. The extra reserve capacity of the battery should make up for the rectification / inversion losses of AC-DC-AC.
-Ben Picture of my rig
