RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): Water tanks
Cumminalong
SW Ontario
Posted: 04/15/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Wanting to extend the water drain outlet so it reaches the edgeof the tank, like to put a tap on it.what can I use? John
SHRED
California
Posted: 04/15/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
A short pipe with a threaded plug? Is your goal to drain it without water pouring all over the place and instead to the ground?
2021 27' Lazy Daze mid bath
JimJohnson
Texas Hill Country
Posted: 04/15/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Assuming it won't spend a lot of time in the direct sun, you can purchase some inexpensive flexible plastic line (not PEX) and a 1/4 turn sink/toilet shut off valve. clamp the line to your current valve and leave it open, controlling the drain from your newly and more conveniently mounted shut off.
This type of valve was installed by the manufacture on our 13 year-old mini travel trailer we use for overnight hops. They still work fine on the fresh water tank and off the PEX low-point drains.
Boon Docker
Posted: 04/15/21 11:05am Link  |  Quote  |  Print  |  Notify Moderator
You can unscrew the fitting that goes into the tank and use PVC fittings and pipe to extend and place a valve on the end.
That is what I did with my tank, extended it to the edge of the trailer frame.
lwbfl
Florida Panhandle
Posted: 04/15/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on what you have, mine is a 2" pipe with a gate valve coming directly out of the bottom of the fresh water tank.
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
midnightsadie
ohio
Posted: 04/15/21 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
use a quarter turn valve and some of the idea,s above, plastic pipe easy to work with.
BILDER
SOUTHERN ILLINOIS
Posted: 04/16/21 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Extend using pex 90with a shark bite style valve with a hose end, to just behind the bumper, now can fill and drain with out getting under the trailer
Cumminalong
SW Ontario
Posted: 04/16/21 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone found a way
RickLight
Washington
Posted: 04/16/21 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Some caution is advised.
I've been told the drain plug melts as a last ditch safety feature.
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
Boon Docker
Posted: 04/16/21 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
Only if the water goes above 275 degrees. [emoticon]
