RV.Net Open Roads Forum: Class A Motorhomes: oil leak
Sir Traveller
La Mesa Southern California
Posted: 04/15/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hello Everyone…
I have a 2003 Ford F-53 RV
Two months ago I did an oil change, the recommended amount was 6 quarts, but most forums recommend adding 5 quarts fits then check the level and add as needed. So I added 5 quarts but got busy and forgot about checking the level and adding more till 2 weeks ago, so I checked the level and added about ¾ of quart… few days ago I noticed an oil leak, I got under the RV and saw the leak was forming around the AC compressor belt, is that normal after oil change? Does that mean I overfilled it? Could it be different type of leak? Or is it a sign of something more serious? Take into consideration I have not drove or moved the RV, I have been hooked up for the last 5 months
Ranger Smith
Wherever the rig is parked
Posted: 04/15/21 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
A picture might help
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
John Wayne
Long Beach, Ca
Posted: 04/15/21 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Engine oil does not flow through the AC compressor so if it is leaking from the compressor it is fluid used for the AC.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Sir Traveller
Posted: 04/15/21 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
https://hosting.photobucket.com/images/i/ryadh1980/IMG_9976.JPG
https://hosting.photobucket.com/images/i/ryadh1980/IMG_9979.JPG
https://hosting.photobucket.com/images/i/ryadh1980/IMG_9980.JPG
https://hosting.photobucket.com/images/i/ryadh1980/IMG_9981.JPG
Sir Traveller
Posted: 04/15/21 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 04/15/21 08:34pm by an administrator/moderator *
MountainAir05
New Mexico
Posted: 04/15/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Have you been running the engine. If not then it got spilled when you put the oil in if you put it in at the engine. As stated engine oil does not go thru Compressor. Is the oil drip clear or the color of engine oil.
CA Traveler
The Western States
Posted: 04/15/21 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
A/C compressors do contain some oil, but make sure the leak isn't above the pully. Are you sure you didn't spill some oil during the oil change?
The belt to the right appears dry which might suggest the leak occurred since the engine was last run because the belt on the compressor is wet.
2014 Grand Cherokee Overland
Bob
ScottG
Bothell Wa.
Posted: 04/15/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
You need to resize your pick to 640 x 480 MAX.
chuckftboy
Fleming Island, Florida
Posted: 04/15/21 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Running a quart low can't cause a leak and really won't hurt anything but it is better to keep it on the full line. Like others have suggested, you probably spilled a little.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Sir Traveller
Posted: 04/18/21 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
I am sure I didn't spill any during the oil change, also I noticed the leak after over a week from the last time I added oil
it looks like engine oil but not sure yet, I just put paper-towels under to see the actual color of the leak, it drips very slowly, about 1 drop every coupe of hours
