RV.Net Open Roads Forum: 18" Equal-i-zer Shank - Hitching with Tailgate Down?
 > 18" Equal-i-zer Shank - Hitching with Tailgate Down?
mrgrim007
CO
Posted: 04/15/21 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Trying to figure out if we can hitch our trailer (on order) to our '14 RAM 3500 with the tailgate down, using an extended shank.
Our tailgate will need to be completely down when hitching - we carry a side by side in the bed.
Looks like the ball will be just at the end of the tailgate, but not 100% sure. Just looking for someone who has done this and can give some insight.
Thanks
2014 RAM 3500 CTD, CC, Longbed
Rockwood 2608BS - On Order
Sold - 2002 Suburban 2500, 8.1L, 4.10
Sold - 2016 Jayco Jayflight SLX 212QBW 25' 6"
Sold - 2013 Jayco Jayflight 32BHDS 35' 6"
nickthehunter
Southgate, MI
Posted: 04/15/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Even if it will hitch, will you be able to turn?
mrgrim007
CO
Posted: 04/15/21 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Good question. Not sure. The other part of this is possibly getting the Jack-E-Up, which lets you easily remove and reattach the tongue jack.
joshuajim
Mojave Desert
Posted: 04/15/21 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
If the wheels are completely in the bed, remove the tailgate. Most take about 30 seconds.
RVing since 1995.
June Lake area, California
Posted: 04/15/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Does the proposed extended shank have sufficient rating for the weight of your TT?
lwbfl
Florida Panhandle
Posted: 04/15/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Not anymore if you have locks and cameras in them. You'd have to install your own disconnect and then you could!
Here's how you know for certain - hook up with the tailgate closed. Now open the tailgate - I'd venture to guess that turning will not be possible unless the jack is below the gate or you remove it.
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
wanderingbob
monticeeo, fla
Posted: 04/16/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
I would think that ya could just aim the truck where ya wanta go and plan on no turns , what could go wrong . I did see a 4 wheeler in the bed with tailgate off and the owner had put 2x8s under the rear wheels that stuck out only about 6 inches . Worked for him !
Huntindog
Phoenix AZ
Posted: 04/16/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Then you could remove that pesky steering wheel that just gets in the way. Would not need a back seat anymore.[emoticon]
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
1020 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
Boomerweps
Hills of PA
Posted: 04/16/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I have the Jack-E-Up tongue jack removable base.
Since I flipped my TT axle, I had to flip my WDH shank, I.e., raising it.
Now, even with the Jack-E-Up, I have to pad the jack base or the tailgate will rest directly on the base when open. Still better than only being able to open the tailgate 20-30 degrees when connected to the TT.
Problem of my own making ;(
Point being, while the Jack-E-Up is a great product, It may not solve this problem depending on the WDH height.
If you blow up my signature pic, you can see how it will still interfere.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
mrgrim007
CO
Posted: 04/16/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I was hoping the 18" shank would stick out past the tailgate, but I don't think it will.
