RV.Net Open Roads Forum: Tech Issues: Inverter
 > Inverter
Welder99
Rushsylvania Ohio
Posted: 04/16/21 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone, I have a 2011 Big Country 5th wheel . Last fall I had a water break and water got into the power inverter. I’m now having issues with it. What would you recommend as a replacement?. Thanks in advance.
pianotuna
Regina, SK, Canada
Posted: 04/16/21 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Do you mean the unit that charges the battery bank? If so, while your terminology is correct--in "trailer speak" they are called converters.
Regards, Don
time2roll
Posted: 04/16/21 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Replace with same. Or post the make and model of the inverter for best answers.
675w Solar pictures back up
Flute Man
Payson, Arizona
Posted: 04/16/21 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I would remove the covers and make sure it is dried out completely. Maybe still damp inside.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
Welder99
Rushsylvania Ohio
Posted: 04/17/21 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Sorry I meant convert, it got soaked by the waterline breaking and yes I dried it out. It does work on and off. My light 12 volt lighting works for a while then slowly get dime draining the battery. I then have to use a charger to recharge the battery because the converter is not charging it up. So its not working. I’m looking at replacing it and wondering what others recommend as a replacement . Ive looked them up win and there’s a bunch to pick from.
BFL13
Victoria, BC
Posted: 04/17/21 07:31am Link  |  Quote  |  Print  |  Notify Moderator
https://www.boatandrvaccessories.com/pro........er-converter-battery-charger-w-led-light
https://powermaxconverters.com/wp-content/uploads/2021/04/PM3-Owners-Manual.pdf
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
naturist
Lynchburg, VA
Posted: 04/17/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
The best advice I can give you is to take it to a Big Country dealer and ask them to fix it.
Two things are clear from your question, OP: (1) that you are not especially technically adept, and (2) you do not have a technically adept best bud to ask. Unfortunately this leaves you at the mercy of an RV service department. But frankly, you are going to end up there anyway because, after all, you aren’t technically adept enough to do otherwise. You might as well save yourself time and aggravation and go there directly.
I do not say this with the intent to malign you. I have an in-law with a PhD, MD, board certification in neurosurgery and psychiatry who is also not adept in electrical or mechanical technology. Brilliant guy, lovely person, give you the shirt off his back, but NOT an auto mechanic or home repair sort of guy.
He, and you, OP, need to hire the work out.
 > Inverter
