RV.Net Open Roads Forum: Centeroid fuel sender location 2002 Monaco Windsor?
 > Centeroid fuel sender location 2002 Monaco Windsor?
fijidad
Escondido, CA
Posted: 04/16/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
The fuel gauge on our Monaco Windsor does not read full...when the tank is full. I'd like to adjust the fuel sending unit...but I don't know where it is. Any help finding it would be appreciated.
CA Traveler
The Western States
Posted: 04/16/21 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
It's on top of the tank and has several wires going to it.
2014 Grand Cherokee Overland
Bob
oldave
Tx
Posted: 04/16/21 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
On my 03 Windsor, the tank unit is accessible behind the pass side fuel door.
The big door isn't made to raise like the other side but if you look under the edge there are 2 straps, detaching those straps will let you lift that door.
You'll have to prop it up, then you'll have room to work.
Take pictures and label the wires and the clocking, the screws are uneven.
You can go ahead and try adjusting but I'm sure you will have to replace it.
They are electronic and seem to finally die.
dougrainer
Carrolton, Texas
Posted: 04/16/21 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
There are 2 adjusting pot screws on top the unit.
1. Is for the 1/4 tank empty readout
2. The other is for the Full to empty readout
When you adjust, you fill the fuel tank full. Once you determine which POT screw adjusts the Main fuel readout, you have to adjust clockwise or counterclockwise VERY slowly and in VERY small adjustments. It takes up to a minute for the needle to move. Very tedious process. HOW much is the needle off full when the tank is full? Doug
Here is a pic of it
https://www.google.com/search?q=adjustin........grc=SuxkvF8zkJ_g_M&imgdii=vqCXpNMZzek29M
fijidad
Escondido, CA
Posted: 04/16/21 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tips...very helpful. I'll dive in to it before long.
Executive
Posted: 04/19/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
As Doug mentioned, you have to turn the screw very slightly to make an adjustment. Be patient as the needle won't move right away. Adjust slightly then wait awhile before checking again. Otherwise, you'll think you have it right and next time you start the coach it'll be off again. The screw is difficult enough to find and reach. I used a mirror to ensure I had the right screw and could see what I was doing....Dennis
On edit: My adjustment screws are on the driver's side, on top of the tank...D
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
