RV.Net Open Roads Forum: Engine idle surges up and down when stopping at lights
 > Engine idle surges up and down when stopping at lights
Larrysr1957
Panama City
Posted: 04/16/21 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
I will check the mass air flow sensor
Thank you
Lt46
Central Florida
Posted: 04/17/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
You don't have a MAF sensor, rather, a MAP sensor. When my 97/460 did the stall at lights I first cleaned and then ultimately replace the IAC which solved my problem.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
Jarlaxle
New England
Posted: 04/17/21 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Pretty sure those engines are speed-density, no MAF sensor.
Agrees with the previous posters-sounds like a vacuum leak.
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. ">
Current rig:
1992 International Genesis school bus conversion
Yankee Clipper
Cairo, GA
Posted: 04/17/21 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Two items that may be a reach: a) check to ensure your gas filler cap is sealing. b) my old 97 460 was hard on exhaust manifold, and warped two of them on the passenger side; both time the engine ran rough until the replacements went on.
Those exhaust manifolds also spit out can bolts as the warp got worse, and could crack a head. Hope this helps,
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
Posted: 04/17/21 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
97 Fuel injected or carburetor.. That "Hunting" is a sign of running rich as i recall on a carbureted engine. Might be dirty injectors. but sure sounds like a fuel issue.... Alas. Not a ford man...
doxiemom11
Victoria TX
Posted: 04/17/21 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
I had a GMC Jimmy that did that. EGR valve kept clogging with carbon. Hubby would take it off, blow it out with air compressor and then it was good for about 3 months. If we didn't do that, the idle got worse and it would stall, service engine light would then come on. The surge is what told me it was starting again and he needed to do that.
Jarlaxle
New England
Posted: 04/18/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Ford went to EFI by 1989.
2112
Posted: 04/24/21 03:04am Link  |  Quote  |  Print  |  Notify Moderator
Do come back and let us know what solved this problem.
2013 KZ Durango 2857
jeromep
Eastern Washington State
Posted: 04/24/21 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Larrysr1957 wrote:
I have a 97 ford 460 that has an idle surge and sometimes stalls when stoppingat traffic signals or signs. The mechanics has replaced the throttle positioning sensor and the idle air control and cleaned the fuel system. The idle rpm's still surges.there are no codes. Any help is appreciated
I think you need to find a different mechanic. They are just throwing replacement parts at the problem, they don't really know what is happening. If they knew what was happening they would have already fixed it. I really don't like it when mechanics throw parts at a problem and you pay for their experiment.
I don't know what the issue is either, but my advice costs you nothing and if I were in your position I'd be more than just a little annoyed at paying for something to not be fixed. But I do know this, 97 was the last year of the 460 on a vehicle chassis. For MY 1998, the V-10 was introduced and a totally new era of computer control was introduced.
The 460 was never built in an OBD or OBDII equipped vehicle, therefore getting codes out of it for diagnostics requires much older hardware. They are technically Ford EECIV (Electronic Engine Control 4), vehicles. Ford used EECIV in just about everything from like 1982 all the way till the OBD era. EECIV had numerous changes and variations over all those years and the computer unit was basically entirely different from vehicle to vehicle. My guess is that only a Ford dealer, or a very well equipped independent shop, will have the proper equipment, probably sitting in a corner or on a shelf, to get the codes and information that might lead to a direct fix. If you can find a dealer or mechanic with a Ford SBDS (Service Bay Diagnostic System) with the 168-pin connector, which is probably what your 460 has to connect to the onboard systems, they might be able to find out what is occurring, assuming that the on board sensors are able to identify an issue.
My point is that if you have a mechanic that is throwing parts at the problem, they don't have the right equipment to complete a diagnostic.
Larrysr1957
Panama City
Posted: 04/26/21 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the information and great advise. I will call around and ask if anyone has this test equipment.
