RV.Net Open Roads Forum: Truck Campers: One jack not functioning AF811
 > One jack not functioning AF811
thealexdexter
Lake Stevens, WA
Posted: 04/16/21 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Happy camping season! Pulled camper out today. One jack was struggling a bit then it stopped working. Fuse is still good. Batteries are older and had been on charger for
Many days prior.
What is proper diagnostic procedure with only one acting up? I would not think battery but as I said they are getting long in the tooth. Maybe high resistance cable or connector combined with older batteries?
Fuse good.
Was thinking to fire up generator and try again. I think this should rule out batteries if it still doesn’t work, but not not positive.
What else to try/check? Thanks I’m advance.
2015 All Terrain GMC Sierra 4x4 CC Duramax
2016 Arctic Fox 811SB
markusbrown
Posted: 04/16/21 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I just had the same problem with my AF811. My jacks are Reico Titan. I called their service support number and they were very helpful. The control panel is located under the sink and they had me switch the two wires for that jack, which were the bottom set with the two right above them. It worked then. The upshot is that the control panel circuit for that jack was defective. I ordered a new control panel which was $500. They had rebuilt ones that I don’t remember the price. They also said that they don’t repair them, they have an outside company do it.
Mark
(This is the first post I made to this site)
thealexdexter
Lake Stevens, WA
Posted: 04/16/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
So you basically made left rear jack become right rear by switching wire to prove jack is not bad and thus control board is?
Sounds easy I’ll give it a try. I do hear relay clicking when trying to lift. Also I feel like wire less has been really spotty past year. Maybe that’s strike two for the controller?
Bert the Welder
Van. Island
Posted: 04/16/21 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a up/down button on the jack or in the camper and did you try it? That'll confirm/deny the remote.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
thealexdexter
Lake Stevens, WA
Posted: 04/17/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
I’m not aware of a button inside. I did try the red remote connected via wire with same result.
Bedlam
PNW
Posted: 04/17/21 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Pull the jack motor head off the faulty jack, run power and see if the motor spins and the jack is siezed. Plug the head into another location to verify motor if it still does not spin which will tell you if it is wiring or controller issues.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
Slymer
Ontario, Canada
Posted: 04/19/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I had same problem with our 2013 AF811. I pulled the cap off the top & got a socket on it. Made maybe just a half turn by hand. Then tried again via controller. All good. That was 2 years ago. Hasn't happened again since.
thealexdexter
Lake Stevens, WA
Posted: 05/22/21 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks lol for the tips. Man access to this thing to get screws off terminal block is terrible. I was able to check a whole bunch of stuff and finally determine a failed fuse on one jack. In swear I checked that first but I guess not. Now I have a new issue. I was lowering all four and all was good. Did some leveling and now none of the jacks work.
Control box has 12vdc and active light comes on.
All fuses on entire control box and in main fuse box all good.
Killed power and reset several times.
Tried wired and wireless remote . Lights on remote control come on.
No lights for the jacks come on on the main control box when pressing remote buttons.
Any idea what to check next? It kind of acts like the remote doesn’t work. Is there a way to manually activate without the remote to see if it’s the remote or something else?
Maybe there is another fuse if I take the cover off the control box?
thealexdexter
Lake Stevens, WA
Posted: 05/22/21 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Just tried to plug wires controller direct to control box and it worked. Then tried wireless. Nothing. Then plugged wires into remote location and all fine again. Ugg. Don’t know what’s going on.
Maybe I’ll change the codes and see if wireless comes back
ICamel
Oregon
Posted: 05/22/21 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
When was the last time you changed the battery in your wireless remote? Mine has to be replaced about every two years. I know its time when the jacks start to act wonky.
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
