RV.Net Open Roads Forum: Truck Campers: One jack not functioning AF811
 > One jack not functioning AF811
thealexdexter
Lake Stevens, WA
Posted: 05/22/21 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
I think it was changed last year. I’ll give it a go…
2015 All Terrain GMC Sierra 4x4 CC Duramax
2016 Arctic Fox 811SB
thealexdexter
Lake Stevens, WA
Posted: 06/22/21 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
I changed battery twice, checked all fuses again. Tried red and black remotes plugged into remote plug and directly to controller. Also made sure I was on the right mode and not trying to move the awning. I also tried another red remote direct wired. Nothing seems to work. I did get one jack to move once briefly.
I did notice that previously I would get the LED lights for each jack to come on red or green....even though nothing was moving. Now those LEDs do not ever come on.
Any last things to try before I blow $500 on a new controller?
mkirsch
Rochester, NY
Posted: 06/23/21 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried calling Reico Titan for advice yet?
thealexdexter
Lake Stevens, WA
Posted: 06/23/21 07:15am Link  |  Quote  |  Print  |  Notify Moderator
That is probably my next move, to call reico. I’m hoping it can be repaired cheaper than $500 for a new one.
brholt
Seattle
Posted: 06/23/21 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure it is not the button on the remote controller.
thealexdexter
Lake Stevens, WA
Posted: 08/05/21 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Finally resolved this. Sent controller back to Reico which was determined defective. $500 later it’s back working. Sure it’s 5 years old not basically it used. Should have lasted longer in my opinion.
Thank you to all for your suggestions on troubleshooting.
Highway Runner
Atlanta, Ga.
Posted: 08/05/21 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
I had to replace two of my jack motors last year. They quit working.
You can just take it off and plug it into a different location. It is a very easy process and will take about 30 minutes. Good luck!
2015 Eagle Cap 1165
2016 F-350 Lariat 4x4, 6.2 Boss Dually, 4.30 Axle
Air Lifter 7500 XL w Rancho 9000s & Torklift Stable Loads
