RV.Net Open Roads Forum: Truck Campers: Eagle Cap quality control continues to disappoint
 > Eagle Cap quality control continues to disappoint
Page of 5
specta
utah
Posted: 04/18/21 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for your reply.
* This post was edited 04/18/21 04:22pm by specta *
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
3 tons
NV.
Posted: 04/18/21 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
notsobigjoe wrote:
AnEv942 wrote:
Yes, heater is missing a duct collar to connect hose. They just spin on into the heater hole.
From here it looks like the hose is way too short to connect but the way its ripped appears it once was connected to something.
Possibly another piece, ext or ell? The pics dont give me the impression it left factory like this..
I dont know if duct collars are brand specific (dometic/suburban) but are available.
With no hose seems most of the air would come out that open port.
[image][image]
I agree! There is plenty of room behind the drawer slide to mount a flange and turn the hose to the rear. Something happened at the dealer I bet. Something stupid. I wonder if the rest of the hose is stuffed up behind the whatever it is in front of it. Also the OP probably had some nice warm undies... [emoticon]
Either of these types (depending on your furnace make) easily threads in with just a twist - Avoid HD, save time and get the right part the first time at a RV shop...
3 tons
Reader1
Ohio
Posted: 04/18/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
We visited the RV/MH Hall of Fame and Museum several years ago. They have a scaled display of a travel trailer being built. A guide talked us through the building and the "inspection" of each part of the build. She ended by stating that the last thing done was a complete inspection of every part of each trailer or motorhome built. The group we were in all burst out laughing. We said we were sorry, but that no longer happens in any brand.
jimh406
Western MT
Posted: 04/18/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Bert the Welder wrote:
See what EC says before monkeying with anything. Don't want to give them an excuse to blame you for the issue.
I’m not understanding why someone would do without their TC for an extended period of time just to determine blame and let the manufacturer fix a minor issue. If this was an extremely hard fix, I could see waiting. Otherwise, I’d fix it and move on enjoying camping.
It’s not that it’s a problem letting Eagle Cap know, but what do you expect them to for the OP other than offer to fix it for him? I guess it’s possible they could send him a connector and hose, but what else?
Bert the Welder
Van. Island
Posted: 04/18/21 11:56pm Link  |  Quote  |  Print  |  Notify Moderator
I'd expect EC to provide the OP with an apology and direct him to go to the nearest dealer to have the repair done immediately, or should the fix be within the OP's abilities and more satisfactory and/or convenient, expedite the needed parts to them. Whichever is preferable to the OP.
Realistic would be the expectation that when you pay ten's of thousands of dollars for a product it should be expected to be in good working order. And not standing up for that basic ideal is why we end up with laziness, lack of workmanship, and consistent decline in quality of both product and the people that make it.
If you're too lazy to stand on principal, then sit down.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
MrPhelps
Huntsville, AL
Posted: 04/19/21 06:18am Link  |  Quote  |  Print  |  Notify Moderator
.. an apology ?
I suspect there will be more issues found over time as the issues reveal themselves..Hope you shake it down to find the more serious potential ones while it's still in warranty.
There are plenty of things that can go wrong with complexity. All of us have stories of quality issues revealing themselves. In my HOST Cascade, after the warranty was up, we discovered a metallic flex water line that was routed through the slide and then under the floor. It rubbed on an aluminum framing edge within the slide with each slide cycle. This SLOWLY abraded the line and eventually caused a significant water leak. It was extremely difficult to get into for replacement...
When replacing we found a roller bearing/ flange assembly that was supposed to be bolted (2 bolts according to HOST) into the floor to help keep the slide level ( no up and down movement) and take the vertical load into the floor as it moved in and out. It was actually attached with two about 1 inch long drywall like screws.. no bolts! The screws had simply pulled out and the roller assembly was laying on the floor flat under the slide, probably like that for a very long time. I called Host for some guidance. They didn't apologize or give any guidance, they simply did not acknowledge .. said that it was bolted (obviously).. a solution that now, out of warranty, would require the entire slide to be removed in order to fix to "factory installation" standards. Never would have seen this one without the other one.. but we found a creative solution to fix this problem too.
- 2018 RAM 3500 Laramie DRW
- 2018 Host Cascade Dual Slide
bighatnohorse
Gig Harbor - Cave Creek
Posted: 04/19/21 07:49am Link  |  Quote  |  Print  |  Notify Moderator
moonlitsouls wrote:
this is why i love this forum , plenty of good feedback and lots of people willing to help out. Thanks a lot. I am going to email the photos to the warranty rep at eagle cap , if for nothing else , to bring this to their attention. Im going to go to home depot and try to find the right flange and maybe a 4 inch to 2 inch reducer of some kind to fit the duct somehow into the furnace
Calling the customer service line would be your first best choice.
They will want photos. And they would love for you to fix it yourself - because the dealership would charge them an arm and a leg to fix it.
Bert the Welder
Van. Island
Posted: 04/19/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
MrPhelps wrote:
.. an apology ?
Yes, an apology for not providing the standard of build one should reasonably expect. Would that be asking too much?
And it is unfortunate to find things that were done wrong from the start, after the warranty expired. But this is a flaw of the warranty enforcement laws. IMO, if something is proven to have been flawed right from the factory, then it was indeed broken during the warranty period and should be covered.
Fantasy of a perfect world? Yep. No disagreement there. But allowing companies to get away with this sort of thing is why these things continue. Host not responding to you is exactly the result of this.
Our only recourse at this point is to post on forums and social media to make others aware so they might avoid the same issues. This hopefully puts pressure on the companies to do better.
moonlitsouls
Everywhere
Posted: 04/19/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
let me know when i can meet you all i want to witness these debates in person. i will let you know what EC says about the photos
Lancey
vancouver
Posted: 04/19/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Is it possible that that hose is actually meant as a return air duct? And not supposed to be connected at all? If it draws air from the bunk area it will create a circulation effect from the lower half of the camper.
2005 arctic fox 990 silverfox
2008 Silverado ltz drw duramax 6speed allison
1999 Kodiak k99 / 2008 ford f450 6spd manual. SOLD
2000 citation supreme SOLD
1989 camperette SOLD
1985 okanagan SOLD
1990 northern lite SOLD
1995 northern lite SOLD
1997 Kodiak k99 SOLD
Page of 5
