RV.Net Open Roads Forum: How to remove tail light from 2020. Rock wood mini lite
 > How to remove tail light from 2020. Rock wood mini lite
Gdetrailer
PA
Posted: 04/20/21 05:45am Link  |  Quote  |  Print  |  Notify Moderator
1ed wrote:
Thanks for all. The responses, I have not repaired the. Light yet. Cleaned the plug on trailer and truck and still no worked. If the blinker works on the truck wouldn’t that eliminate the truck. I plan to use some emery paper as my next method to repair the light.
Many newer vehicles use relays and separate fuses to isolate the trailer connection from the vehicles turn signals..
So, it is possible to have the vehicles turn signals work but yet the trailers not if a fuse blows or relay fails.
Compounding things a bit more is recent vehicles have switched over to "smart modules" to handle the trailer lights, these modules are able to detect a load present and turn on or off the output.. These modules are a bit sensitive to shorted trailer wiring and can go into a protect mode and never come back.. The only nice thing about smart modules is they will notify you of a trailer light outage fault.
If you have the lights posted by another member, it may be possible that the glue/caulking is holding them in place. If so cut or remove the caulking and see if they come off..
If all else fails, check with a RV dealer service department to see if they will clue you in on how to remove.
Gdetrailer
PA
Posted: 04/20/21 06:13am Link  |  Quote  |  Print  |  Notify Moderator
This might be helpful..
Using the pix posted by another member I was able to locate a similar tail light to what they posted.
Brand is Optronics 6" round..
Found
HERE
RVSTL10 is passenger side (no license plate bracket)
Found
HERE
Lense is removable, will need to remove the caulking and the lens will have to be pried off to get to the mounting screws.. Look on the underside flat area for any place to insert a flat blade screw driver between the red cover and the plastic base.
And yes, I have run into LED tail lights that failed prematurely so it is possible that you could have a defective light but if you can get the red lens cover off you can check the wiring to make sure it is the light.
1ed
Northern California
Posted: 04/21/21 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
PROBLEM SOLVED...It was one of the fusses that are under the cover of the battery box..
Saved some money and time, THANKS FOR ALL THE SUGGESTIONS
Gdetrailer
PA
Posted: 04/22/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Glad you found the problem!
Thanks for posting what was wrong, may be helpful for someone else.
Posted: 04/22/21 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Good deal. Sometimes a fuse blowing is an anomaly. Most of the time it’s due to a live short somewhere that overloads the circuit.
It may hold now but blow again , underway, if there’s a bar wire somewhere.
Just to keep in mind
2017 Heartland Torque T29
1ed
Northern California
Posted: 04/22/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
I had forgotten all the fuses under the battery box cover. I looked at the fuses on the dash but not the ones under the box cover. Reading the OWNERS MANUAL was helpful in reminding me of the other fuses. Again, thanks for all your help. Ed
