RV.Net Open Roads Forum: Fifth-Wheels: Water hook up Solitude 369RL
 > Water hook up Solitude 369RL
klr650goldwing
minnesota
Posted: 04/16/21 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
First day of first trip of the season and the water doesn't work. Water from the spigot works, water from the hose works, attach the hose to the trailer and no water in the trailer. On the water valve there are only two possible options, city water hook-up and normal. Neither one produces water in the trailer. What else could I be doing wrong?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
K Charles
Connecticut
Posted: 04/16/21 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Fill the tank and use the water pump.
jdb7566
minnesota
Posted: 04/17/21 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Make certain all the levers on the water control panel are in the proper position for what you want to do. Rotate all the levers a few times as one may be stuck closed. Check the inlet screened washer for debris.
Monterey, California
Posted: 04/17/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I’ve seen some nasty water damage from burst lines. X2...fill the tank and use the pump.
BB_TX
McKinney, Texas
Posted: 04/17/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
How many different water hose connection points fo you have? Don’t know about Solitudes but my Montana has 3; fresh water, winterize, and tank flush. And the labels on Montanas are not always clear as to which is which. Must connect to the fresh water port to get fresh water to the trailer.
garyp4951
TN
Posted: 04/19/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Nautilus valve panel
