RV.Net Open Roads Forum: Truck Campers: Need Advice
 > Need Advice
Originalwingman
Posted: 04/18/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
I purchased a 2010 F150 SuperCrew, that calculated to a payload of 1800 lbs.
I purchased a 2018 Travel Lite truck camper that was labeled at 1280 lbs.
I installed the Timken suspension enhancement system because the truck sagged when bringing the camper home.
With the camper and truck fully loaded with my wife, myself, full tank of gas, and all my gear, the truck is perfectly level front to back. No sagging, and seems to handle fine driving.
Now I’m scared because the Cat Scales show that my rear axle is overloaded by 1,140 lbs, and the gross vehicle weight is overloaded by 1,400 lbs.
Has anyone else been traveling with this high of a overloaded vehicle and been ok?
The guy I bought the camper from had the same truck as me and traveled from Michigan to Yellowstone and back without problems.
I need suggestions and help because I can not afford a F250.
Thank you
Near DVNP, California
Posted: 04/18/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
If you are over manufacturer’s specs you are courting danger. Being “level” is great but you’re over by a bunch. Lighter camper.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
cooldavidt
Vancouver
The scales don't lie!
I had the same problem on a previous TC. I upgraded my rims and tires, Drove on the paved smooth highway and was ruthless in leaving 'gear' at home.
Also it may not sit well with your insurers if you were in an incident and you were almost 1005 overloaded
MORSNOW
Mountain Home, ID
Posted: 04/18/21 08:45am Link  |  Quote  |  Print  |  Notify Moderator
You found out what many have said on here thousands of times, those factory weight labels are not even close to accurate for an actual built weight (1,280 lbs right?). It's probably closer to 1,800 lbs before you added anything inside. Your 150 series truck tires are probably WAY overloaded too. A 250 is really needed.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
jimh425
Western MT
Posted: 04/18/21 08:48am Link  |  Quote  |  Print  |  Notify Moderator
I’m sure someone has, but based on your post, you are almost double the payload of your truck.. If you are planning on only doing one trip, maybe you’ll be lucky just like the person who drove from Michigan to Yellowstone and back.
As far as can’t afford a F250 goes, there are large variations in prices of diesel vs gasoline. I’m not sure you can afford the wreck by leaving the rig you have. Also, consider a F350. You can go all of the way back to early 2000 and have a very capable gasoline proper sized truck.
The biggest danger you have is tires. They will be fine until they fail. Next, are your brakes. Since you are double the recommended payload, I don’t think it would be unusual for other components to fail as well.
Finally, you are severely limited in what you can carry with you being already way over payload. It doesn’t sound like fun to me.
BradW
Mayor of Flat Rock
Posted: 04/18/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
A couple of things to consider. The vast majority of hardside truck camper carrying SRW trucks you see on the road are over their gvwr. Also, many axles are rated based on the tire/wheel package they originaly came with. The same axle may have a higher gawr on a different truck. You never want to exceed the maximum payload rating of any tire.
* This post was edited 04/18/21 10:14am by BradW *
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
MFL
Midwest
Posted: 04/18/21 09:29am Link  |  Quote  |  Print  |  Notify Moderator
BradW wrote:
A couple of things to consider. The vast majority of truck camper carrying SRW trucks you see on the road are over their gvwr. Also, many axles are rated based on the tire/wheel package they originaly came with. The same axle may have a higher gawr on a different truck. You never want to exceed the maximum payload rating of any tire.
This ^^^^^hedging a little on GVWR, not the best idea, going over the RAWR even worse, but going well over tire/wheel ratings, not acceptable!
Jerry
MFL
Midwest
Posted: 04/18/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
My neighbor has a 2019 GM 1500, with a pop up top, truck camper on it. Loaded, he is likely over some ratings. Here it comes...he also hooks his heavy boat, with tandem axle trailer on truck receiver, and drives 120 miles, up/down hills to the river. Yup, two summers now, works great! [emoticon]
Jerry
BradW
Mayor of Flat Rock
Posted: 04/18/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
If I had a half ton truck and wanted a truck camper, I would be looking at a pop up tc, not a hardside.
toedtoes
California
Posted: 04/18/21 11:28am Link  |  Quote  |  Print  |  Notify Moderator
The first mistake people make is using the camper's dry weight to determine if the vehicle is enough to tow or carry a camper.
ALWAYS use the GVWR of the camper. You may end up with less actual weight, but you won't be overweight.
Years ago, my aunt's then husband overloaded the year axle of their station wagon with firewood. The axle broke on the way home and he was in the hospital lucky to be alive.
Is it worth the risk to "be lucky"?
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
 > Need Advice
