RV.Net Open Roads Forum: Tech Issues: Solar Panel Height
 > Solar Panel Height
1L243
Oregon
Posted: 04/18/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
I posted this at the end of a old thread but I think it has ran it's course.
After viewing many photos of RV Solar Panel installs I see a big difference in the distance between the roof of the RV and the solar panel. Some appear less than a inch some 5" OR 6" from the roof to panel.
In my case I used Renogy two piece mounting brackets and as low as I could go is about 3" on the ends. My roof has a curve so a little less in the center of the panel.
I have to admit I like the look of the panels being closer to the roof but what is the ideal or is there a ideal recommended height for solar panels.
I did read that 3" is minimum with 4" to 6" preferred but not sure if they were referencing RV's or solar panels in general.
Apparently the height has to to with heat from the solar panels, just how hot does it get under there?
Any thoughts?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
2oldman
NM
Posted: 04/18/21 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are at a height of maybe an inch or two, as determined by the standard commercial mounts that allow tilting. They've been up there for a decade, in almost constant sun, in 90F or more temps (not Death Valley heat) and my rubber roof shows no signs of heat damage.
What I love about solar panels, other than the obvious, is they actually protect your roof from damaging sunlight.
The panels that scare me are the flexible ones I see plastered directly on a roof. Those things get really hot.
agesilaus
North Florida
Posted: 04/18/21 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah mine are maybe 1 1/2 inches. They are supposed to work better when off their above the roof for cooling.
"I did read that 3" is minimum with 4" to 6" preferred but not sure if they were referencing RV's or solar panels in general."
But on the other hand people are sticking those flexible panels right on their roofs. Zero spacing.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Williams AZ area
Posted: 04/18/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are less than two inches. Five, six inches would be funny lookin’ IMO.
Being a Westerner, the heat of stick-on panels would be terrible. Has thecupping issue been solved? Is the warranty now equal to rigid panel warranties?
pianotuna
Regina, SK, Canada
Posted: 04/18/21 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are as close as possible given a curved roof.
If I redo the system in summer of 2022, I'll have a rack that is above the air conditioner.
Regards, Don
1L243
Oregon
Posted: 04/19/21 01:25am Link  |  Quote  |  Print  |  Notify Moderator
Now that would be something to see going down the road.
jshupe
FT
Posted: 04/19/21 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Rack is the way to go. It avoids shading and gives you maximum use of space.
2019 Ram 3500 HO/AISIN CCLB DRW Longhorn
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
1L243
Oregon
Posted: 04/19/21 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Having a solar array rack not like the one in the picture which looks pretty fixed but one that could tilt all the panels remotely would be pretty cool.
https://www.youtube.com/watch?v=9IndjBauuRc
mr_andyj
Georgia
Posted: 04/19/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Make it as low as possible.
Some guys have super high mounts to clear objects on the roof as otherwise the panels would not fit between the objects.
Some might be trying to get above any shadows that the object could cast.
Some have high mounts because the mounts they bought are high, no other reason.
Some have them high bc they have it set up to be able to rotate the panels at an angle when parked, so need the extra wiggle room.
Others yet have absurdly high mounts bc they are crazy.
The panels do need an air gap so the air can circulate, it can get hot under those black cells.
How much of a gap is debatable, but 1/2 an inch will allow cooling. Yes, a big gap will allow more cooling, but that small gap will circulate plenty of air.
Keep in mind you will be driving and if you care about the mpg's a lower stack is better.
I prefer the panels low to the roof where minimal wind turbulence will occur.
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 04/22/21 02:24am Link  |  Quote  |  Print  |  Notify Moderator
I've got about 2" under my panel and none of my RV's have caught fire yet from the heat...
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
