RV.Net Open Roads Forum: Tech Issues: toilet bowl water
 > toilet bowl water
huskyfan68
usa
Posted: 04/19/21 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
trailer only 2 years old- Toilet bowl not holding water- So my guess is - it could be the seal. When i depress pedal- it opens but need water to stay in bowl. My neighbor says it has to be something stuck in there- ( i don't see anything). Any suggestions? if it is the seal- how do you change it?
bob213
Fresno, CA
Posted: 04/19/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Clean the seal and then lube with Plumbers Silicone or olive oil. DO NOT use anything petroleum based. Replacement varies by type of toilet.
opnspaces
San Diego Ca
Posted: 04/19/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Mine did that a few weeks ago and I also couldn't see anything in there. I put on a latex glove and with the pump turned off I held the valve open with one hand. Then I reached down and ran my gloved finger around under the seal and around the blade. I never felt anything foreign, but it now holds water again so I'm happy.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Ed_Gee
Central Oregon coast
Posted: 04/19/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I never let the bowl go dry...... with water always in it my seals never get dry, which maintains their ability to seal.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
enblethen
Moses Lake, WA
Posted: 04/19/21 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Thetford toilets have a double seal gasket where the blade slides in.
Thetford made/makes a tool to clean it.
I made one out of a metal coat hanger. I bent one end with about a one inch point. The length is about 6-8 inches. Insert short into groove to remove any debris.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
stro1965
Nebraska
Posted: 04/19/21 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the seal in mine yesterday. Took 5 minutes. Very easy job.
2018 Ram DRW 3500 6.7
2019 Keystone Alpine 3021
Jframpey
Charlotte
Posted: 04/19/21 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Check out “RV toilet seal replacement” on YouTube... dozens of videos!
Terryallan
Foothills NC
Posted: 04/19/21 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Agree. Especially when winterizing. I always put pink in the bowl to keep the seals wet, and lubed
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
rexlion
Broken Arrow OK
Posted: 04/19/21 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
Strange that this works for seals but not for dolphins... [emoticon]
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
larry cad
ohio
Posted: 04/20/21 04:51am Link  |  Quote  |  Print  |  Notify Moderator
https://encrypted-tbn0.gstatic.com/shopping?q=tbn:ANd9GcQ3RWIjNAfyJ4OlG13w3ewuU43onFyZqnvzPAU3_ha86cSBOvY
Our Travel Blog
 > toilet bowl water
