RV.Net Open Roads Forum: Tech Issues: Battery wing nut size
 > Battery wing nut size
ndrorder
Southwest
Posted: 04/20/21 10:39am Link  |  Quote  |  Print  |  Notify Moderator
My Centennial batteries are 8 mm. FYI
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
ndrorder
Southwest
Posted: 04/20/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
wing_zealot wrote:
swimmer_spe wrote:
BurbMan wrote:
Yes, most common size is 5/16-18 threads here in the US. Not sure if Canadian batteries would have metric studs?
I know it's not metric as one has studs that fit a 1/2 inch wrench.
Right there is your answer, if its 1/2 inch nut/wrench it's a 5/16 inch bolt.
My batts are threaded 8 mm. Standard wrench size for 8 mm is 13 mm which is almost indistinguishable from a 1/2" wrench.
red31
Dallas
Posted: 04/20/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
energizer specs https://www.eastpennmanufacturing.com/wp-content/uploads/Marine-Master-Spec-Sheet-0194.pdf
toedtoes
California
Posted: 04/20/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
clicky
IF the OP knew the actual battery model, this would provide the answer needed.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
swimmer_spe
Sudbury, Ontario, Canada
Posted: 04/20/21 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
swimmer_spe
Posted: 04/20/21 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you
Fisherman
Angus, Ontario, Canada
Posted: 04/20/21 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
On some batteries the positive are 3/8' and the negative are 5/16", others, both are 5/16. I keep a couple of each in the trailer spare parts bin.
mobeewan
Hampton, Va
Posted: 04/20/21 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
mobeewan wrote:
Some are 3/8 inch & some are 7/16. Carry both.
You mean 5/16.
Yes 5/16 not 7/16.
swimmer_spe
Posted: 04/20/21 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
OP here
So, I was going to need wing nuts for one of the batteries. Turns out it is stone dead. So, I will see if a local auto service shop can charge it as mine can't. If not,t he need for wing nuts is the least of my worries.
Fisherman
Posted: 04/21/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
OP here
If the battery is too far gone, hook it up in parallel with a good one and then hook up the charger. Some chargers need to "see" some voltage before they will begin charging.
