RV.Net Open Roads Forum: can a ford ranger tow trailer on steep mtns rds?
Search only in Towing
Open Roads Forum  >  Towing
 > can a ford ranger tow trailer on steep mtns rds?
Page of 5
EASY.RIDER
Mo
Posted: 04/20/21 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
I want to use this 2021 ford ranger, with a 4 cy engine with turbo on it to tow a trailer, while traveling in mountain roads, pulling about 4500 lbs.
I also will tow it behind my motorhome in some cases. thanks, Tom
Williams AZ area
Posted: 04/20/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Slowly but yes. Does Ford say your Ranger is four down towable?
jshupe
FT
Posted: 04/20/21 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Going up, you'll work the engine and spend the entire climb in boost. I doubt power will be an issue, but wear might be in the distant future if you tow often enough.
Going down I expect you'll be working the brakes because I don't imagine that engine/trans will offer enough hold back for the truck and 4500lb trailer to be of much use. Sounds like you might be setting yourself up for some white knuckle descents, but I've never tried that combination and I doubt many others here have.
I know my old Ecoboost 3.5 struggled to hold speed coming down 7-8% grades with a ~6K trailer, or at least scream doing it and still required some assistance. Your smaller engine will be notably less effective.
2019 Ram 3500 HO/AISIN CCLB DRW Longhorn
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
bgum
South Louisiana
Posted: 04/20/21 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't mind pedestrians passing you it should be just fine. Thats a lot of weight.
Williams AZ area
Posted: 04/20/21 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
jahupe make good points about DEcending.
time2roll
Posted: 04/20/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Keep the trailer GVWR within your tow rating for best results.
Watch the hitch weight does not use up all your payload.
675w Solar pictures back up
carringb
Corvallis, OR
Posted: 04/20/21 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
So apparently 270 horsepower is insufficient??? That’s more than the original v10 made.
OP- the same motor has been in the Explorer for some time, and I’ve never heard a single power complaint.
2014 ORV really big trailer
2015 Ford Focus ST
EASY.RIDER
Mo
I should have added, with the tow pkg added it is rated capable of towing 7500lbs. however I am very concerned weather this truck can handle my load going up steep inclines and also going down hill. This same pkg has been used in the 2019,2020 and now the 2021 models. Tom
Williams AZ area
Posted: 04/20/21 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Weather is an additional factor to consider IMO.
wanderingaimlessly
SOBOVA
Posted: 04/20/21 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Since it's within the specs from the factory, it's a fair bet that ,,,,
Yes it will pull it.
Will that little 4 banger be screaming?
Most likely.
Will it provide enough drag on downhill slopes?
Likely not , without a lot of braking.
Do they offer a Tow/haul mode on those? Some method of forced downshifting would make a big difference, and with it, it may not be bad.
Page of 5
